Author Topic: Help! Did I just toast a brand new monitor?!!!  (Read 1655 times)
markymarky99
  • Last login:August 20, 2017, 01:53:05 pm
« on: June 28, 2006, 07:34:35 pm »
HI, I installed a brand new VISION PRO 1949-1329-VP2" shelf mount monitor from happ controls (49-1329-VP2) .  All was fine for about 20 minutes, then I noticed a smell in the air.  Suddenly, I lost my picture.  I looked in the back and what i found was a black ground wire lodged up against what looks to be a heat sync or something.  This had melted the plastic wire coating and made contact.  After removing the wire from it's resting place,  I tried to fire up the monitor, it briefly fires up and then immediately shuts down.  Because I had to remove the monitor from it's original frame, the warranty is no longer in effect.  How do I fix this problem or is this entire chassis now toast?  UHG,, thanks for your input.  I'VE INCLUDED A PIC OF WHERE THE PROBLEM IS.
Ken Layton
  • Guru
  • Technician
Re: Help! Did I just toast a brand new monitor?!!!
« Reply #1 on: June 28, 2006, 11:18:11 pm »
It's possible that you may have fried the component attached to that heat sink. You may have cooked the horizontal output transistor and/or the B+ power supply regulator transistor.
markymarky99
« Reply #2 on: June 28, 2006, 11:56:34 pm »
Hi Ken,, thanks, is this repairable or do I have to spend 92.00 from Happ for a new
chassis ?
Q*Bert_OP
  • Oh yes, we did!
« Reply #3 on: June 29, 2006, 12:00:18 am »
Aw man, that sucks...but it's most likely repairable
Ken Layton
  • Guru
  • Technician
« Reply #4 on: June 29, 2006, 12:46:51 am »
Should be repairable.
