Author Topic: Second Hand 29" Monitor  (Read 1504 times)
whiterino06
  • Last login:September 14, 2009, 03:58:02 pm
« on: May 01, 2006, 07:36:00 am »
I have 2 x 29" computer monitors I want
lettuce
  • Make It So!
Re: Second Hand 29" Monitor
« Reply #1 on: May 01, 2006, 02:15:23 pm »
Would be very intrested, what make, how old are they?? So there not Arcade monitors then just PC
whiterino06
« Reply #2 on: May 01, 2006, 02:35:09 pm »
I live near Gatwick, which is south of london
the computer monitors are second hand,
and are OCM-2846 MULTIDATA II   if that means
anything to you. If you do a google on it you
get some info on the second result.
Hope this helps
Al
Any one that wants to contact me can on
077236 30837
First come first served
whiterino06
« Reply #3 on: May 01, 2006, 02:36:29 pm »
or they can email on
botley2001@hotmail.com
Good luck
Silver
  • Last login:February 17, 2024, 10:29:00 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #4 on: May 02, 2006, 10:12:10 pm »
I would have been interested a few months ago before I picked up a 28" nec.....
For those interested, these monitors are made by Barco, and in theory perfect for genuine arcade video reproduction:
They take RGB in, and are specced to sync up on everything from 15Khz-36Khz (800x600). So they should work on EVERY arcade mode (15Khz/25Khz/31Khz), as well as work as a PC monitor up to 800x600 (SVGA).
I only say in theory as I've not physically tested one myself...
exiges
  • Last login:November 24, 2006, 02:57:03 pm
« Reply #5 on: May 04, 2006, 09:03:32 am »
Specification:
Manufacturer:  BARCO
Model:  OCM-2846 MULTIDATA II
Also Known As:  OCM 2846 MULTIDATA II
Monitor Type:
VGA frequency compatible:  Yes
VGA sync compatible:  Yes
Max Resolution:  800 x 600
H Freq/ V Freq:  15-36 khz / 45-120 hz
Sync Type:  Sync on Green, Composite, Seperate
Connector:  BNC, HD15
Atomiswave
  • Last login:June 26, 2006, 01:19:02 pm
« Reply #6 on: May 04, 2006, 11:16:55 am »
If the picture and the the convergence is good I urge you to buy these monitors. Barco is known to manufacture high quality stuff. This is a quad-sync monitor for you people :)
