Author Topic: XBCD Driver compatibility question...  (Read 1169 times)
struby
  • Last login:April 23, 2007, 08:42:05 pm
« on: March 29, 2006, 09:10:50 pm »
I have 4 pelican real arcade joysticks, and i am trying to get the xbcd driver to work with them, but...
When I install the driver, and plug in the device, it recognizes the device and installs an HID Complient Controller Driver automatically, without bringing up a window, how can I get them to install, do I need to mess with the ID Vendor and ID Product, and how would I find that info for my joysticks?
BurningDog
  • Last login:April 02, 2006, 10:51:02 am
Re: XBCD Driver compatibility question...
« Reply #1 on: April 01, 2006, 07:55:42 am »
That should be all you have to do to install them (assuming they work just like a standard xbox controller).  Open the XBCD setup utility from the start menu or from the joystick control panel and test them.
If they're not working, post on the XBCD development board.
struby
« Reply #2 on: April 01, 2006, 05:32:38 pm »
Thanks for the help.
I pretty much decided to take the buttons joysticks and microswitches out of them and go with an Ipac, but still, thanks.
