Author Topic: Arcade power supply test bench  (Read 7986 times)
SirPeale
  • Green Mountain Man
« on: March 05, 2006, 09:26:48 am »
Just a quicky on how I rigged up a test fixture for Peter Chou PS's.
Five bulb in fixtures, wired in parallel.  Puts adequate load so it doesn't shut down.
Needed to build it as I got a boatload of PS's that we were going to toss.
Ken Layton
  • Guru
  • Technician
Re: Arcade power supply test bench
« Reply #1 on: March 05, 2006, 11:50:22 am »
Peter Chou's are the easist, simplest, and cheapest to repair. Best ones out there. I NEVER throw away a Peter Chou!
grantspain
« Reply #2 on: March 05, 2006, 04:58:54 pm »
Hey Peale,that rig you made looks like one of those ancient lie detectors 8)
SirPeale
« Reply #3 on: March 06, 2006, 07:39:54 am »
They did.  I snagged like thirty of them.
Funny thing is, 90% of them have absolutely *nothing* wrong with them.
fredster
  • It's all good!
« Reply #4 on: March 06, 2006, 10:34:17 am »
Until you put a load on them for a while. That's why they took them out.
Is there a Peter Cho "cap kit"?  Don't they take a special type of capacitor for high frequency?
Ken Layton
  • Guru
  • Technician
« Reply #5 on: March 06, 2006, 10:47:50 am »
Clean off the circuit board and inspect it for bad solder joints and replace a few capacitors and you'll be good to go.
The ones I've found with problems under a load have been bad solder joints, especially on the ones with a terminal strip soldered directly to the board.
The special orange "low ESR" capacitors for this power supply are sold by Betson-Imperial. These capacitors actually say "Peter Chou" on them!
AlexC
  • Last login:May 06, 2012, 05:18:05 pm
  • "Beware, I live!"
« Reply #6 on: March 06, 2006, 10:57:20 am »
PM me if you're going to be selling some of them, I could use 2 or 3 of them if cheap ;D .
Ken Layton
  • Guru
  • Technician
« Reply #7 on: March 06, 2006, 06:23:51 pm »
What amperage is the +5 line on these? Are they all the same like all 12 amp, etc?
What color is the case painted, green or gray (that tells how old it is)?
SirPeale
« Reply #8 on: March 07, 2006, 01:20:51 am »
There are green ones, grey ones, even black ones.
I had them under a small load, about 1.25A.  That's 5 44 bulbs wired in parallel (see the rig above).  I need a bigger load to see what's going on, but the ones I tested so far didn't have obvious cap issues (ie bloating).  There were *very* obvious ones.  There were ones that were _not_ obvious, but certainly had a problem (like couldn't get more than 5.5v from them, and squealing like a pig)
Ken Layton
  • Guru
  • Technician
« Reply #9 on: March 07, 2006, 10:39:52 am »
Squeling is definitely bad capacitors that are just about to explode!
Call Betson and order these Peter Chou capacitors:
2  # 55-4100 Capacitor, 3300 uf @ 16 volt
2  # 55-4110 Capacitor, 1000 uf @ 16 volt
1  # 55-4120 Capacitor, 470 uf @ 25 volt
I call 1-800-828-2049 (extension 720) Kevin Cardea which is Betson's west coast office and mention I sent you.
Each power supply uses the quantities listed above. I automatically change these out. Those particular ones are the ones causing the squeal and/or low output voltage.
Here's some info on the coloring of the cases:
Green: the very first ones to hit the USA. Generally only 7 amp and the first 11 amp ones were this color.
Gray: the newest. Part of the 11 amp production run, all 12 amp, and all 15 amp were gray.
Black: Not a genuine Peter Chou. This is a clone. Probably a Pan-Yes or Chu-Far brand.
Blue: Not a genuine Peter Chou. This is a clone. Probably a Pan-Yes or Chu-Far brand.
Red: I have heard of but not seen a red cased one.
The Pan-Yes and Chu-Far have their name on the circuit board.
SirPeale
« Reply #10 on: March 07, 2006, 07:35:59 pm »
They don't *have* to be Peter Chou caps, do they?  I just used regular hi-temp caps in one I just fixed.
Ken Layton
  • Guru
  • Technician
« Reply #11 on: March 08, 2006, 02:12:01 am »
The original (orange) ones are "low ESR" type capacitors. You can use regular electrolytic or hi-temp electrolytics ok.
