Author Topic: Bug - Viewing in Various Formats  (Read 8752 times)
Tiger-Heli
    • Tiger-Heli
« on: February 22, 2006, 07:29:52 am »
Top Left Corner is messed up in Opera and IE, looks fine in FireFox.  Doesn't affect usage, just visual appearance.  FYI, FWIW
« Last Edit: February 22, 2006, 07:33:27 am by Tiger-Heli »
sirwoogie
  • Supreme Chancellor
  • Last login:April 23, 2025, 10:29:35 pm
  • It's Hollyfeld in a Winnebago!
Re: Bug - Viewing in Various Formats
« Reply #1 on: February 22, 2006, 10:57:27 am »
Tiger,
I've tested with this Opera 6, Opera 7, IE 5.5 and IE 6.0 and do not get your result with either anonymous browsing or logging in. You might have something on your local system causing this.
Does anybody else get these rendering errors?
saint
  • turned to the Dark Side
  • Last login:November 22, 2025, 12:26:51 pm
« Reply #2 on: February 22, 2006, 11:18:00 am »
Renders properly here in IE 6 and Firefox 1.07.
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: February 22, 2006, 11:20:24 am »
Opera problems went away when I bypassed Proxomitron.   :P
Not sure what's going on in I.E. - IE 6.0.2900
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #4 on: February 22, 2006, 02:36:13 pm »
Looks fine here on IE 6.0.2900.2180 sp2 (whatever happened to just calling it 6.1?) and Firefox 1.5.0.1
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: February 22, 2006, 02:46:30 pm »
Text at top of page in IE says this, if this helps:
Warning: Cannot modify header information - headers already sent by (output started at /www/html/wiki.arcadecontrols.com/w/extensions/Auth_smf.php:505) in /www/html/wiki.arcadecontrols.com/w/includes/OutputPage.php on line 455
Warning: Cannot modify header information - headers already sent by (output started at /www/html/wiki.arcadecontrols.com/w/extensions/Auth_smf.php:505) in /www/html/wiki.arcadecontrols.com/w/includes/OutputPage.php on line 456
sirwoogie
« Reply #6 on: February 22, 2006, 03:12:37 pm »
Try this now.
Yeah, I saw that in your image dumps.
Try now. I have a hunch I fixed it.
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: February 22, 2006, 03:32:48 pm »
Yep - looks good in IE now.
Thanks SirWoogie!!!!
sirwoogie
« Reply #8 on: February 22, 2006, 07:06:05 pm »
Bah, what a stupid problem. For all of you PHP jockies out there, do not have trailing whitespace after the closing ?> in a <php ?> bracket. I had an extra CR at the end of the authentication module, and that is what caused it.
How stupid.
saint
« Reply #9 on: February 22, 2006, 09:40:18 pm »
Heh. Good catch.
How stupid.
--- John St.Clair
     Project Arcade 2!
