Author Topic: Vertical MAME32  (Read 3106 times)
Gradius
  • Last login:February 04, 2008, 03:10:49 pm
Vertical MAME32
« on: February 14, 2006, 05:30:22 pm »
This is for MAME32 users, or users of unofficial builds based on MAME32. I have an ArcadeVGA and I'd like to know if there's a way to make MAME32 gui rotate, so as to view the list of games correctly when I have my tv rotated. I think there's an option in the drivers that lets you rotate windows, but games won't load under MAME32 when that is enabled. It must be some kind on incompatibility. I wonder if there is any build to have a rotating gui or any frontend which is exactly the same as MAME32 but with the ability to be displayed vertically.
markb
  • Last login:April 30, 2011, 06:41:02 am
  • The One and Only.
Re: Vertical MAME32
« Reply #1 on: February 14, 2006, 06:29:13 pm »
I had the same problem and eventually settled on 3DArcade. It's default configuration is in horizontal mode however with a little bit of work it can quite easily boot up in a vertical mode.
BTW I went through about 10 frontends and a couple of rotation programs before I this mind you.
loadman
    • MaLa
Re: Vertical MAME32
« Reply #2 on: February 14, 2006, 06:51:53 pm »
..Dito. But I settled on MaLa FE (good/simple rotation options)
« Last Edit: February 14, 2006, 08:56:21 pm by loadman »
PrizLucky
  • Last login:April 28, 2010, 09:42:32 am
  • It's good to be lucky
    • My arcade blog
Re: Vertical MAME32
« Reply #3 on: February 15, 2006, 05:01:12 pm »
I went through several FE's (not as many as 10 ...)  and I'm using Kymera.. Easy setup and simple to get running rotated vertically.   So many choices in FE's.. everybody likes something slightly different.. :)
daywane
  • GRRRR!
Re: Vertical MAME32
« Reply #4 on: February 15, 2006, 11:02:37 pm »
program called pivot pro
i was studing on mame's ini files yesterday
I think I say you can rotate mame.s menu . I can not swear to this but I think I saw it. I will take  look.
I think I am wrong about the ini.... I can not find it now.
atomic FE will work
If you like the mame 32 GU, I pivot pro will flip windows vertical
« Last Edit: February 15, 2006, 11:29:26 pm by daywane »
juggle50
  • Last login:July 18, 2024, 07:25:48 am
  • Your either on the bus or off the bus
Re: Vertical MAME32
« Reply #5 on: February 15, 2006, 11:44:02 pm »
If your graphics card supports rotation "irotate" is also an excellent and very simple rotational software program.  I've used pivot pro successfully in the past, but some people have said that it can do some weird things sometimes.
loadman
    • MaLa
Re: Vertical MAME32
« Reply #6 on: February 16, 2006, 12:11:57 am »
YEP...  as does Nvidia.    Only on some games
markb
  • The One and Only.
Re: Vertical MAME32
« Reply #7 on: February 16, 2006, 12:18:02 pm »
Pivot Pro flat out refused to work on my system, it would rotate the screeen but would not work when playing a game. If I remember rightly it messed with Direct draw and no amount of tinkering with the settings got me a rotated mame menu and games that would have the right colours and fill the screeen.
juggle50
Re: Vertical MAME32
« Reply #8 on: February 16, 2006, 02:30:12 pm »
get irotate.  It should work like a charm.   http://www.softpedia.com/get/Tweak/Video-Tweak/iRotate.shtml
loadman
    • MaLa
Re: Vertical MAME32
« Reply #9 on: February 17, 2006, 04:27:03 pm »
g
Thanks for the link to the Free download.
However it is no more than a frontend for your rotate compatible video-cards it doesn't actually do the work itself. This explains why the file is so small.
So in my case with a Nvidia card it has the same problems on some games as before. Thanks anyway   :D
juggle50
Re: Vertical MAME32
« Reply #10 on: February 17, 2006, 06:14:08 pm »
Yeah, it is pretty much just a fe however,  It's supposed to be more stable than the nvidia interface for the driver.  Howard Castro is pretty much the rotation expert.  Here is the link regarding the benefits.
I use ATI though and have no problems.
http://forum.arcadecontrols.com/index.php?topic=29605.msg248470#msg248470
daywane
  • GRRRR!
Re: Vertical MAME32
« Reply #11 on: February 19, 2006, 05:49:16 pm »
strange. I have put pivot pro on many computers.
never once a problem.
other then collapse II and DVDs do not flip
