Author Topic: Just decased my first tv, pics included  (Read 3166 times)
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« on: November 07, 2005, 02:15:36 am »
I decided to go for it, and I'm very, very happy ;D.
« Last Edit: November 07, 2005, 02:56:56 am by mccoy178 »
Sinner
  • Last login:September 17, 2024, 11:27:45 am
  • Half the lies they tell about me, aren't true...
    • Geek My Gadget
Re: Just decased my first tv, pics included
« Reply #1 on: November 07, 2005, 04:20:19 pm »
Did you move the brackets from the original monitor, or did you just cut off the threaded part, and drill new holes???
Goo job, by the way...
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #2 on: November 07, 2005, 04:48:54 pm »
I cut off the threaded part on the bottom brackets.  I also had to cut the brackets a little to get it to fit.  Now figuring out how to get it to power on.................................................
Jess--
  • Last login:April 05, 2023, 09:51:55 am
    • My Botched Cab
« Reply #3 on: November 08, 2005, 07:32:20 am »
for power on I am assuming that the screen is coming on in standby mode when you give it mains (if I am wrong ignore the rest)
to get a tv to come out of standby have a look at the mains switch, quite often you will find that there are 6 connections in use (4 big ones for mains + 2 smaller ones) in most switches like this the 2 smaller ones are a second switch that has a momentary action when you press the switch which kicks the tv out of standby mode as you first turn it on (check with a meter for continuity by pressing the switch with mains removed)
if your switch is like this then there is a few ways you can handle it (experiment with them)
1... short the switch (some tv's will power up, others will fire up and then shut down again)
2... put a capacitor across the switch (ensuring you select a suitable value for the voltage present on the switch and matching polarity, this capacitor charges up when the mains is first applied, the charging process appears like a short to the set and makes it act as if the switch has been pressed)
3... run wires from the switch to an external switch on the cabinet (can be a standard arcade switch)
« Last Edit: November 08, 2005, 08:17:54 am by Jess-- »
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #4 on: November 08, 2005, 08:34:49 pm »
I'm sorry, I phrased that wrong.  I need to wire the power on so that I can turn it on from outside the cabinet.  The t.v. now runs fine.  Thanks for the info though!  I am open to ideas on how to wire a volcano button to the actuator switch in the bottom right of the photo.
Jess--
    • My Botched Cab
« Reply #5 on: November 09, 2005, 01:57:08 pm »
there will be 4 connections on that switch, 2 on each side,
to activate that switch you should just need to short from one side to the other. the voltages that switch can handle you should be safe to experiment with a short length of wire to find out exactly which pins to link, once you have found the pins attach a wire to each and run tose to you external switch (I am assuming that when you say volcano switch you are meaning a normal arcade type button / switch)
markrvp
  • NFL Expert
« Reply #6 on: November 09, 2005, 05:28:33 pm »
Can you measure the widest part of the de-cased monitor (including the mounts).  I have a NEO-GEO cabinet that is 24-3/4" wide.  Most commercial 27" monitors are 1/2" too wide to fit.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #7 on: November 10, 2005, 04:14:53 am »
It is 24"'s exactly from "ear" to "ear".  That is the bolt holes for the bracket on the very edge of each.
mamerocks87
  • Last login:March 17, 2007, 12:21:33 pm
« Reply #8 on: November 10, 2005, 05:43:16 pm »
Hows the picture look? When you get it all sat up could u put a pic of the desktop showing?
-kyle
nice job
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #9 on: November 10, 2005, 05:52:54 pm »
I sure will!
mamerocks87
« Reply #10 on: November 14, 2005, 08:31:32 pm »
Got er up and running yet? Just wondering, if it looks pretty good then im yankin my arcade monitor out and using a tv like the one you got.  I just didnt know how good the small text on the desktop and stuff like that would look.
-kyle
MaximRecoil
« Reply #11 on: November 15, 2005, 09:09:47 am »
Glaine
  • Last login:April 24, 2013, 12:09:17 pm
« Reply #12 on: November 16, 2005, 03:07:41 pm »
*Jealous*
Thanks a billion for sharring this, I too am considering doing this now, very well done. Like the other chap said, please post some pics of windows and your front-end so we can check how details look.
As for powering up, I shelled out the $30 and bought a Smart Strip, it's great - powers up my speakers, marquee, and monitor when my PC comes on. But thats just cuz I wouldn't know how to/wouldn't want to do the TV mods or power strip mods found on byoac. I like being alive.  :)
(Can I say that after being thrown into the air from taking a shock off my broken Neo-Geo? Meh...)
Glaine
« Reply #13 on: November 16, 2005, 03:49:36 pm »
oops I missread you, the telle doesn't do auto-power on. I was thinking of something else. Hrmph. I'm a lot less temped by this then if it won't auto-power-on.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #14 on: November 17, 2005, 02:53:34 am »
This is my second cabinet.  My first one has a cases 27" flat screen.  It does have power on, so the smart strip is great.  This one will be no problem to connect a simple microswitch or some other device to power on at the side of the cabinet.  I am still in the primer/painting process, so the t.v. is out of the cabinet for now.  I can say this, I have been quite happy with S video on my other cabinet.  Here is a  screenshot of my flat screen.  I will post close ups when I get the chance.  The major point of this thread was to show that us noobs can do this.  I have a million ideas, but I can never find dumb little threads like this to show the obvious, sort of just to double check that the idea is what I thought.(If that makes any sense?!)
thebrownshow
  • Last login:December 14, 2010, 03:14:32 pm
« Reply #15 on: November 17, 2005, 12:24:31 pm »
I've got to say, the Smart Strip was the best thing I ever bought for my cabinet.  I plugged my cabinet into the switch plug, set my mobo to "Restore Power after AC Power Loss", plugged in my speakers, and ran the Smart Strip's plug out of the back of the cabinet.  When I turn on the cabinet, the PC powers up and the speakers turn on.  Simplest one-switch solution there is.
