Author Topic: 3" Imperial Trackball--Need install photos  (Read 1506 times)
MAME nut
  • Last login:March 18, 2024, 12:33:01 am
« on: October 24, 2005, 03:25:41 pm »
Hi,
I purchased a 3" Imperial Trackball, but it did not come with install directions.  Can anyone post pics of their CP??  Both front and back??
THANX !!!
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
Re: 3" Imperial Trackball--Need install photos
« Reply #1 on: October 24, 2005, 04:49:25 pm »
Did you get a mounting plate with it?  If not, you really should pick one up.  The housing mounts to the mounting plate which has holes for carriage bolts to attach it to the CP.
-Ace-
I want my own arcade controls!
MAME nut
« Reply #2 on: October 25, 2005, 09:44:21 am »
It came with a faceplate for the top of the CP....do I also need a mounting plate??
What size/shape hole do I cut??
Do I need to router the CP??
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
« Reply #3 on: October 25, 2005, 10:26:55 am »
You need the Happ mounting plate.  As far as the hole, just lay the TB correctly down, trace around it, then cut out the hole with a jigsaw.
NinjaEpisode
  • Last login:June 16, 2019, 06:47:45 pm
« Reply #4 on: October 25, 2005, 11:00:30 am »
Actually, I think that "faceplate" you speak of, is actually a spacer so you can flush mount or leave a lip on the trackball.
The mounting plate works perfect.  I think DreamArcades sells them fairly reasonable.
tk_42_1
  • Last login:November 17, 2010, 03:43:24 pm
  • I suggest a new strategy...Let the Yorkie win!!!
« Reply #5 on: October 25, 2005, 02:31:06 pm »
Here are some pix for you:
First one shows the 3" trackball with the spacer on top of it and the mounting plate.
Second shows the hole I cut out for the trackball and the holes for the mounting plate.
tk_42_1
« Reply #6 on: October 25, 2005, 02:36:36 pm »
Two more pix:
First is Trackball mounted from the bottom.
« Last Edit: October 25, 2005, 02:38:29 pm by tk_42_1 »
MAME nut
« Reply #7 on: October 26, 2005, 10:13:01 am »
THANKS.....
Pictures are worth a BILLION words!!
