Author Topic: mala and mame 32 .ini file  (Read 8360 times)
grayxx
  • Last login:July 27, 2006, 07:25:32 am
« on: September 23, 2005, 07:36:08 pm »
hi guys
im using mala frontend which is great in my cocktail cabinet, so its used with vertical layouts, im also using mame 32 with it, but when i click on rotate mame with mala in the settings and then go to run a game from mala it says mame.ini file missing whats this as i cant seem to figure it out??, ive tried the command line version of mame with mala and this works fine but it takes longer to load and comes up with a black box in the middle of my mala layout when a game is loading which spoils the look a little bit, all help much apreciated guys.....
loadman
  • Moderator
  • Last login:Yesterday at 07:59:17 pm
  • MaLa FE developer
    • MaLa
Re: mala and mame 32 .ini file
« Reply #1 on: September 23, 2005, 08:42:46 pm »
G'day,
Mame 32FE does not rotate (just the games do) . MaLa is looking for the command line version of mame becuase of the options you must have set. I don't think running Mame32 from a FE is worth it anyway in my opinion.
Ive tried the command line version of mame with mala and this works fine but it takes longer to load
Don't use the latest version of mame. I use .80 as I don't want to play the latest games (just the 80's stuff). It loads very fast. http://www.mame.net/zips/mame080b.zip
« Last Edit: September 23, 2005, 10:01:58 pm by loadman »
grayxx
« Reply #2 on: September 24, 2005, 05:42:21 am »
loadman thank for your reply, done all the above and it works great, much better now thanx for yor help your a star, take care m8.....
