Author Topic: MAMEWAH 1.61 and MAME .97 Filtered List  (Read 1544 times)
giza
  • Last login:November 12, 2005, 08:52:17 pm
« on: July 07, 2005, 04:38:12 pm »
Just in case some of you haven't figured out how to get the filtered list feature working in MAMEWAH v1.61, you need to get the lastest catver.ini file http://www.mameworld.net/catlist/.  Once I downloaded the new file an used MAMEWAH Config 1.61.1 to generate my list using ROM Folder and -listxml (post .84 versions of MAME), the filtered list options showed in MAMEWAH.
Something else that I have notice is that there are two list for each platform in MAMEWAH, one is filterable and the other is not filterable.  In order for your filter options to show, you need to select the list that is filterable.
« Last Edit: July 07, 2005, 04:55:07 pm by giza »
Re: MAMEWAH 1.61 and MAME .97 Filtered List
« Reply #1 on: July 08, 2005, 06:42:22 am »
Actually you don't need catver to use filtered lists, you just need to generate the list (using listxml, listinfo or a suitable dat file).  Catver is only required if you wish to filter on game category.
Correct, but you can have as many filtered lists as you want (just add new emulator-?.ini files).  One list (the first one) is always non-filterable.
giza
« Reply #2 on: July 08, 2005, 01:46:45 pm »
Thanks Minwah for clearing up some things for me.  Now I feel better about being able to config MAMEWAH a little better.
