Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: Playchoice 10 issues  (Read 1760 times)
a_w_hodge
  • Last login:July 20, 2005, 12:12:42 pm
« on: June 29, 2005, 04:35:04 pm »
I have a Playchoice 10 that won't seem to completely power on.  The monitor is getting power and the board is getting power.  The monitor is just grey.  Not sure if this is a power supply problem or a board problem.  HELP!!!!
SuperGunGuru
  • Last login:March 22, 2014, 07:29:56 am
  • Filling up that basement
Re: Playchoice 10 issues
« Reply #1 on: June 30, 2005, 02:36:49 am »
What happens why you coin the game up and try to play it?
a_w_hodge
« Reply #2 on: June 30, 2005, 12:17:59 pm »
I can't even get the machine to a point to play it.  When I power on the cabinet I just get a grey screen.  All the fuses are good and not burned out.  Not sure what the issue is.
Ken Layton
  • Guru
  • Last login:Today at 10:39:15 am
  • Technician
« Reply #3 on: June 30, 2005, 12:20:53 pm »
Is the gameboard even plugged in?
If so, and there's no loose socketed integrated circuits then you likely have a power supply problem.
a_w_hodge
« Reply #4 on: June 30, 2005, 03:45:14 pm »
Yeah I checked all that out last weekend.  I took it out the PCB board last weekend and then I put the PCB board back into the cage and then re-plugged the board back in to the cage connector then re-connected the cage connector back to it's connector.  Where can I buy another power supply for this cabinet?  I've been asking around and no one seems to have one.  Thanks again for assistance!!!
Ken Layton
  • Guru
  • Technician
« Reply #5 on: June 30, 2005, 07:02:33 pm »
Nintendo used their own special switching power supplies. No one manufacturers a new plug 'n play replacement. You may have to go to arcadeshop.com and buy a Nintendo to modern switching power supply adapter harness.
a_w_hodge
« Reply #6 on: June 30, 2005, 09:00:21 pm »
Thanks for the information!!  I will check them out and see if they have a power supply
SuperGunGuru
« Reply #7 on: July 01, 2005, 11:47:04 am »
I have a Donkey Kong cabaret that will sometimes give me a grey screen. I'm almost certain it's the power supply so that could very well be your problem as well. If you email Todd from tntamusements.com he can sell you an original Nintendo power supply for $20 plus $8 shipping (IIRC). I need to order me one of those someday ;)
