Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: How do I remove wood glue?  (Read 2173 times)
Thurman
  • Last login:March 12, 2018, 09:15:33 pm
  • The suspense is terrible . . . I hope it'll last.
« on: May 30, 2005, 10:52:49 am »
Anyone have any tips for loosening wood glue?
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
Re: How do I remove wood glue?
« Reply #1 on: May 30, 2005, 11:12:06 am »
When I had to remove some control panel sides due to poor construction, I used a hammer to knock the panels off. Granted, the glue was not very old, and I had room to swing the hammer. You might not.
Once you knock out pieces, you'll have to sand down any left-overs.
CJK
  • Last login:January 22, 2010, 10:33:07 pm
  • All your ROM are belong to us!
« Reply #2 on: May 30, 2005, 02:19:33 pm »
The bad news is that aliphatic wood glues (as opposed to the older hide-based glues) are basically stronger than the wood fibers themselves.
You'll have to either knock the pieces apart carefully or use a pry bar.
-- Chris
Underway: Joey's Arcade
