December 02, 2025, 10:08:00 am
For my 3" imperial I cut a hole the size of the trackball case. Then from inside the top half of the case I screwed into the edges of the hole I cut. The only problem is the vinyl overlay shows the edges of the trackball case more than I'd like it to. You can download templates of what the trackball mounting plate is and if your good with metal or have a friend you can make one.
Do most of you who have a Wico TB mount it by screwing through the plastic case into the side of the wooden control panel, making the top of the control panel flush with the top of the trackball's plastic housing?Marco
