Author Topic: Wico Trackballs  (Read 2476 times)
marcopolo
  • Last login:September 28, 2011, 02:11:53 am
  • Life's a ---smurfette---
Wico Trackballs
« on: November 24, 2002, 11:07:31 pm »
I would like to use the Wico 2 1/4" trackball on my first MAME cabinet.  I have two questions and would appreciate any feedback..
1. What is the difference between the "Active High" and "Active Low" model trackball?  Which should I get if I am using an Optipac?
2. I am choosing the Wico trackball over the Happs Model mainly due to price (about $60 less).  Is the Wico similar in performance to the Happs, or is it definetely not the same quality / feel as the more expensive Happs?
any advice is greatly welcomed.
Mark
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re:Wico Trackballs
« Reply #1 on: November 25, 2002, 05:25:19 am »
Both work with optipac; you just change a jumper on the optipac board.  IIRC, all the new 3" are active LOW, so you might want that model 2 1/4".  But does not matter, really.
I don't have a 2 1/4" happs, but the wico 2 1/4" is solid arcade quality.   (BTW, Wico and Suzo 2 1/4" trackballs are the same thing.)  Someone who has tried both will know more, though.
Robin
Knowledge is Power
Superdude
  • Last login:January 22, 2016, 11:53:48 am
  • Mo' Betta Butter with da Betta Playa'
Re:Wico Trackballs
« Reply #2 on: November 25, 2002, 12:18:22 pm »
Why not go 3 inch imperial with ps2?  Only 38 bucks on ebay.  I bought mine here and it works great!
BTW you dont need a optipac for it.  Just plug in and go!
eightbit
  • My cab is never done...
Re:Wico Trackballs
« Reply #3 on: November 25, 2002, 02:24:12 pm »
I bought 2 imperials off ebay for $22 a peice. Its a pretty good ball. My only complaint is that its not sensitive enough but I've got a fix for that by replacing the encoder wheels with ones that have more holes.
gtjoe
  • Last login:November 04, 2006, 05:06:20 pm
Re:Wico Trackballs
« Reply #4 on: November 25, 2002, 02:48:20 pm »
What encoder wheel did you use?  How many teeth?
I was going to replace the imperial encoder wheel with some printed on a transparency using the EncoderPrinter utility at http://www.arcadecontrols.com/arcade_downloads.shtml#Utilities
I wonder if the improved Oscar encoder wheels would work as replacements
eightbit
Re:Wico Trackballs
« Reply #5 on: November 25, 2002, 03:18:03 pm »
I'm not sure of the number of spokes. I got the encoder file from another poster here at BYOAC. My first attempt at printing them didn't work, I think I used to thin of a transparency as it wouldn't stay flat. I haven't gotten around to trying it again.
