Author Topic: 1, 2, A, B Grounds for J-Pac  (Read 786 times)
kenzo42
  • Last login:March 07, 2023, 09:50:13 pm
« on: April 24, 2005, 01:27:17 am »
why does the j-pac use these 4 grounds if there is no power 5v, 12v, -5v going to it?
on the ultimarc website, it says that these connections are used by the j-pac??? will the j-pac still work w/ out these 4 grounds?
SirPeale
  • Green Mountain Man
Re: 1, 2, A, B Grounds for J-Pac
« Reply #1 on: April 24, 2005, 08:01:05 am »
It's just ground; there's really no reason you'd want to cut it off.  It's getting ground from the PC.
kenzo42
« Reply #2 on: April 24, 2005, 02:36:28 pm »
Hey Peale,
I understand that the pc has it's own ground. However, I notice that the 8 grounds traces (from pictures I've seen) are still intact, thus being used. The locations for these 8 grounds are 1, 2, A, B, 27, 28, e, f. Can you tell me what these traces lead to?
I need to split one of those grounds or find one that's not used (for a needed total of 9 grounds, jpac uses 8) to ground a 5v line. I will be powering something from this 5v line.
Thanks.
SirPeale
« Reply #3 on: April 24, 2005, 02:41:25 pm »
The grounds are all connected.  Get +5v from the power supply.
kenzo42
« Reply #4 on: April 24, 2005, 02:47:46 pm »
I would, but I need to load +5v from my cabinet's psu, not from the PC psu. My cab's PSU goes into overload mode w/ out a board (ALL my wiring is jacked through the PSU, so I can't remove it). So I'm going to just load my PSU w/ a dummy jamma board, thus the 5v.
I just read this on Bob Robert's site, which is essentially the same thing you said:
<<The PCBs ground traces are all linked together on both sides of the board, so any place that is designated as ground on the PCB, is just that, logic ground, and unites all logic ground into one common termination back to the supply grounding point at your source of DC power.>>
So I'm assuming by splitting a ground, there won't be any problems since they are all linked together.
« Last Edit: April 24, 2005, 02:50:17 pm by kenzo42 »
krick
  • Last login:February 08, 2023, 08:30:27 pm
  • Gotta have blue hair.
« Reply #5 on: April 24, 2005, 04:40:59 pm »
Would this help at all?...
http://mame.3feetunder.com/jpacmod/
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
SirPeale
« Reply #6 on: April 24, 2005, 04:43:09 pm »
I'm going to suggest you rewire.  Having all the cabinet's AC wiring isn't the greatest idea.  And having to wire a PCB just so it doesn't blow?  Even less good.
dabone
  • Last login:October 31, 2023, 12:03:37 pm
  • Time to work...
« Reply #7 on: April 24, 2005, 04:48:57 pm »
Most cab power supplies have lug terminals.
If you must keep the cab wiring intact just remove the ac inputs from the power supply. (You can either clip the spade ends off and wire nut them or just wrap them with electrical tape.)
Then just add the voltages you need back to the wiring harness (i.e. +5 or +12).
Later,
dabone
