Author Topic: Anyone ever try to make a lighted Marquee holder?  (Read 5074 times)
2PacMan
  • Last login:November 06, 2009, 08:33:45 am
  • PacMan collection
« on: March 08, 2005, 02:06:12 pm »
Anyone ever try to make a lighted Marquee holder to display the Marquee itself.  Something like a wood box with a light in to display a marquee that you could sit on a desk or something??
I think it'd be a cool addition to a game room and it wouldn't be that hard to make, and it'd look better than just hanging the marquees from a wall.
Chris
    • Chris's MAME Cabinet
Re: Anyone ever try to make a lighted Marquee holder?
« Reply #1 on: March 08, 2005, 02:57:26 pm »
These are called "lightboxes", and they are fairly common projects.  Also used for displaying pinball backglasses/translites.
--Chris
--Chris
2PacMan
  • PacMan collection
« Reply #2 on: March 09, 2005, 10:22:16 am »
Do you know anywhere i can get some specs on how to build a lightbox?  It would be for a standard arcade marquee.
Stingray
« Reply #3 on: March 09, 2005, 11:48:04 am »
Well, you build a box of the correct width and height to fit the marquee and the correct depth to fit a flourescent light fixture. There isn't a lot more to it than that.
-S
Chris
« Reply #4 on: March 09, 2005, 11:56:33 am »
Vent holes would probably be good, too.
--Chris
2PacMan
  • PacMan collection
« Reply #5 on: March 09, 2005, 12:32:07 pm »
-S
Well, i pretty much figured that out myself :)  I was hoping someone had all the measurements already, because i've got the marquee measurements (23'' by 9'') but you have to make the sides slightly longer for a border of some sort and i wasn't sure on the depth.  Like how far away should the light be from the back of the marquee?  I don't want to burn the back of the marquee.
Vent holes are a good idea.
RoboG2
  • P&R
  • Last login:August 15, 2008, 10:21:26 pm
« Reply #6 on: March 10, 2005, 08:56:05 pm »
You could put the marquee in between two pieces of glass (or maybe plexi, lexan, etc.), you could probably put the flourescent light pretty close.  Doesn't seem to hard to make though.
Chris
« Reply #7 on: March 11, 2005, 08:15:16 am »
Just look at any cabinet plans and match that depth.  If that will make the box too deep, you could use LED's or cold cathodes to light the box and you could use a much shallower box that way.
--Chris
--Chris
