Author Topic: mame changing my ini !?!?  (Read 1175 times)
stevejt
  • Last login:January 01, 2022, 01:21:32 pm
  • stevejt.com
    • My site
« on: January 13, 2005, 07:23:59 pm »
I found out about the skip validity checks recently on here.  My mame computer is only a 700, so the command saves ALOT of loading time.  Especially when checking a new game, 30 seconds is along time to wait just be able to tell at the opening screen you would never play it.
The Problem:  Every now and then the skip validity checks is missing from the ini.  One day it's there, and the next day it's not.  I am NOT making any changes in any settings or configurations.  Any ideas?
Steve
stevejt
  • stevejt.com
    • My site
Re: mame changing my ini !?!?
« Reply #1 on: January 13, 2005, 07:43:39 pm »
mame32 .88 in case that helps...
Steve
rod
  • Last login:February 12, 2005, 10:07:28 pm
« Reply #2 on: January 15, 2005, 03:16:44 am »
We both are looking for the same thing with no results.Hopefully somebody knows.
Anyway if you find something let me know
Thanks anyway
« Reply #3 on: January 15, 2005, 09:13:50 am »
Never seen that happen.  Try commandline MAME?
stevejt
  • stevejt.com
    • My site
« Reply #4 on: January 15, 2005, 09:46:33 am »
Thanks anyway
Sorry it's happening t youtoo, but it's always good to know that you aren't the only one with a certain problem...
Steve
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #5 on: January 16, 2005, 02:32:24 am »
Mame32, ah...
Mame32 rewrites the ini every time you change any settings.  This is a mame32 feature; official mame doesn't do this.
I don't use mame32 much, but it's possible 0.88 doesn't have that option in the settings windows in a box to check/upcheck.  If not, then mame32 doesn't have that setting to write, so it's "removed" from the ini.
Try to find that settings in mame32's settings windows; if you can't find it, well, there's only a few things to do:
Never open mame32 settings.
Make your ini file read only.
Try a newer mame32 and see if this option was added. (If not, see above two...)
Robin
Knowledge is Power
stevejt
  • stevejt.com
    • My site
« Reply #6 on: January 16, 2005, 03:49:54 pm »
That would explain it.  I thought because it wasn't a normal config option, it might be doing that.  I know I didn't make any changes, but now that I think of it, my sons (8 & 10) use it sometimes.  THey might have pulled up an option box and just okayed it to close the window.  Thanks for the verification!
Steve
