Author Topic: Possible to convert Comp 8-way to a 4-way?  (Read 1696 times)
Tokey
  • Last login:June 14, 2007, 07:52:16 am
« on: December 28, 2004, 11:34:42 am »
I decided to make a 2 player CP for my cab, and now i've got 2 extra 8-way comp joysticks.  Is it possible to add some sort of restrictor or is there some kind of switch to make this a 4-way?
Tokey
Re: Possible to convert Comp 8-way to a 4-way?
« Reply #1 on: December 28, 2004, 04:16:18 pm »
no one? I could have sworn I read how to do this somewhere.
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #2 on: December 28, 2004, 04:23:50 pm »
I don't believe its advertised as switchable and Oscar's review posted here:
http://www.oscarcontrols.com/joycompare/joyreview1_4.htm
seems to support that belief.
Assume it would take some sort of restrictor plate offered by someone else or created by yourself.
Tokey
« Reply #3 on: December 28, 2004, 04:26:11 pm »
meh i'll just order a comp 4-way for $9
coachcarstens
  • Last login:November 19, 2007, 10:42:59 pm
« Reply #4 on: December 28, 2004, 08:13:27 pm »
I am also interested in doing this.  Does any have a method to creating a ristrictor plate?
spidermonkey
  • Bombjack junkie
« Reply #5 on: December 29, 2004, 12:43:43 am »
I don't believe there's any such thing as a Happ Competition 4-way. At least its not in my Happ catalog. If Happ sticks are your brand of choice then You could use a Happ ultimate with the 4-way actuator (part#95-1307-00). You could get a Happ Super which has a two sided 4/8-way actuator that you flip over to change modes. Both of these sticks will sufice as a 4-way joystick but there are better choices out there if you're looking for a "dedicated" 4-way joystick ie.classic Wicos,original Midway Pacman sticks,Happ Pacman/Galaga reunion sticks as well as 8/4-way switchable sticks from Ultimarc and Groovy Game Gear. To my knowledge no one currently makes a 4-way actuator or restrictor plate for a Happ competition stick. The Comp stick was designed as a dedicated 8-way stick and though it certainly can be done through the use of a homade restrictor or actuator it probably isn't the best choice for converting into a 4-way when there are so many better choices out there.
"Sinistar has bad breath"
subzero23
  • Last login:April 24, 2017, 03:21:43 am
« Reply #6 on: December 29, 2004, 07:56:13 pm »
the ultimate joystick 4-way is absolutely horrible for 4-way games
go with the ms pacman/galaga reunion 4 way
This user has been banned by saint and cannot reply. --- saint
