Author Topic: How Do I Get ArcadeOS To Start Up & Shut Down?  (Read 1564 times)
Irrek0
  • Last login:September 25, 2004, 06:45:37 pm
« on: October 07, 2004, 09:33:13 pm »
Hi I am trying to get ArcadeOS to start up automatically by itself when I turn on my computer. I also want my computer to shut down  when I exit ArcadeOS so I will never see Win98 at all. Does anyone know what I have to do exactly to do this?
SirPeale
  • Green Mountain Man
Re:How Do I Get ArcadeOS To Start Up & Shut Down?
« Reply #1 on: October 07, 2004, 10:06:37 pm »
ArcadeOS is a DOS program.  You may want to consider using MameWAH instead.  And for that, you'll change the shell from win.com to mamewah.exe
Irrek0
« Reply #2 on: October 07, 2004, 11:23:27 pm »
Would I have to Delete ArcadeOS before i install Mamewah?
SirPeale
« Reply #3 on: October 08, 2004, 02:26:50 am »
You can if you want to, it's only a concern if drive space is at a premium.
coldrain
  • Last login:October 29, 2004, 06:42:33 pm
  • INSERT COIN..!
« Reply #4 on: October 08, 2004, 03:56:53 am »
Hi there, if you run arcadeOS in dos its possible to get your machine to boot stright into arcadeOS, never seeing WIN98. you need to add a couple of lines to your autoexec.bat file and change your MSDOS.SYS file.
1. Go to C: and change your folder to view all files.
2. open MSDOS.SYS in notepad and change the BOOTGUI=1 to BOOTGUI=0
3. In your autoexec.bat file add the lines:
CD C:\ARCADEOS
ARCADEOS
CLS
This should boot your computer stright into arcadeOS in around 5 seconds. I have added a small program to my arcadeOS folder called "ATXOFF"  that I found while searching the net, if you add the line: ATXOFF with this program in the folder the machine shuts down and windows is invisible.
hope this helps.
Irrek0
« Reply #5 on: October 08, 2004, 08:53:43 pm »
How would I go to C: and change my folder to view all files?
