Author Topic: Act-Labs Light Gun is here- Mame Problems  (Read 7996 times)
ArcadeFX
  • Last login:November 10, 2004, 11:16:56 pm
  • All the Dude ever wanted was his rug back!
    • ArcadeFX
« on: September 03, 2002, 04:56:14 pm »
Okay, my long wait it over and my Act-Labs gun has arrived. PC games work great. But.... in MAME I can't get any game calibrated!  It fires way off screen. I have downloaded in updated to MAME .61 (mame061b.zip) but no luck. Do I need to do anything special to get it calibrated in MAME?
I have read a few posts on "enabling light gun support in mame."  How do you physically do this?
hyiu
    • www
Re:Act-Labs Light Gun is here- Mame Problems
« Reply #1 on: September 03, 2002, 05:05:08 pm »
I think you need the windows version of it.... Mame32.. not Mame... cos I think I read their web site... it uses DirectX... so... dos version of Mame will not work with the gun...
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
« Reply #2 on: September 03, 2002, 05:25:25 pm »
You don't need MAME32 (although it will work), but you do at least need the Windows command line version of MAME, from www.mame.net.
I use that version.  In order to enable Lightgun support, I had to use a command line parameter to create a mame.ini file, then edit that file.  There's a parameter in that file that you must set = 1 to enable the lightgun.
slug54
  • Last login:June 12, 2014, 09:00:21 pm
  • Man, I hope this cab fits through the door way!
    • Arcade Extreme
« Reply #3 on: September 03, 2002, 07:40:05 pm »
What you have to do to use the lightgun with the command line version of mame is use the  "-lightgun" option for example to start police trainer you would type
mame policetr -lightgun
I mainly use mame32 because I find it easier to make changes to specific games this way but for some games that I need a little speed boost I will run the cl version
it seems to run just a tick faster.
Oh and if your wanting to play Zero Point don't bother
the aim is off about 2" to the left and a little high! I hope sombody finds a way to fix this. That game was the main reason I purchased the gun! I have since found police trainer and now the whole familys hooked.
                                Good Luck and
                                   Game On!
                                     Slug54
Xiaou2
  • Last login:Today at 07:13:21 am
  • NOM NOM NOM
« Reply #4 on: September 03, 2002, 07:48:17 pm »
also, read my post on lightgun accuracy
RacerX
« Reply #5 on: September 04, 2002, 11:31:31 am »
I noticed that, too.  I thought maybe I just didn't have something set up right for that particular game.  Glad it's not just me.
