Author Topic: Gauntlet/Atari joystick  (Read 1530 times)
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« on: August 28, 2004, 11:10:50 pm »
Anyone know how to take these apart?  No matter what I've tried I can't get the pin out of the center.   :(
Any tips greatly appreciated.
~telengard
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
HighNoon
  • Last login:December 08, 2023, 08:21:37 am
Re:Gauntlet/Atari joystick
« Reply #1 on: August 28, 2004, 11:23:09 pm »
I'm not sure if it's anything at all like the Pac-Man joystick I just disassembled.
My center pole had become "fused" with the metal of the centering grommet (rust).  A few shots of WD-40 and then a few swift taps on the end of the pole with a small hammer and it eventually broke loose.
Like I said though, I'm not sure if yours is similar or not, but I hope this helps.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: August 29, 2004, 02:31:06 am »
I believe you need a "pin punch".  (After wd-40, etc)
Try umm.. http://shop.store.yahoo.com/tmt/pinpunchset.html (first link found)
Robin
Knowledge is Power
telengard
    • S T U R C A D E
« Reply #3 on: August 29, 2004, 04:00:55 pm »
That did the trick on the big one, thanks.  I seems there is a very small one too on the bottom and I managed to break the appropriately sized punch on that one.  It's in there *very* good.
telengard
    • S T U R C A D E
« Reply #4 on: September 05, 2004, 10:58:13 pm »
Finally got the joystick apart and built a module for it.  Ready to play some Gauntlet and Rolling Thunder.  Unfortunately it is **very** loose.  I have no idea which part needs to be replaced.  The spring?  Hat thing on top?  Actuator?  I looked at the Gauntlet Operators Manual but it seems the top and bottom halves were the only parts.   :(
Anyone have an idea?
