Author Topic: arkanoid spinner pinout needed  (Read 5207 times)
menace
« on: July 03, 2004, 06:32:37 pm »
Does anyone have an arkanoid who could take a picture of the spinner guts for me?  I need to see the color of wire going to each lead to figure out which pin is which.  Thanks in advance
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
Re:arkanoid spinner pinout needed
« Reply #1 on: July 03, 2004, 09:41:07 pm »
Here's a thread with a couple of picturs of some other optic boards.   I have been able to figure out some optic boards from similar pictures by tracing the circuitboard and seeing which ones go to the resistor:
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=9837;start=msg73421#msg73421
menace
« Reply #2 on: July 03, 2004, 10:09:31 pm »
cool!  thanks--I'll see if I can piece it together based on that.  I'll post pics back in that thread for a running spinner pinout page.
MrBond
  • Last login:March 10, 2012, 03:50:37 pm
  • ...The name's Do......Mr. Do!...
« Reply #3 on: July 03, 2004, 10:15:02 pm »
I have an Arkanoid running on my cab.  The pinout is as follows (left to right)
Green     Black     Red     Blue
X1        GND      5V       X2
As far as the placement, here's a cheesy picture (sorry my cam is not very good at closeups)
...they only live twice!...
(>")>----MAME----<("<)
menace
« Reply #4 on: July 04, 2004, 08:45:09 am »
Thanks--I have that exact setup and it doesn't work so I suspect I have a spinner optics failure or the optipac isn't registering it (unlikley since the trackball works fine--but you never know)  Guess I'll try replacing the optics and see if that helps...
Aceldamor
« Reply #5 on: July 04, 2004, 11:08:02 pm »
heh...glad to know i've contributed at least a little to this hobby that benefits everyone else  ;D
Fuzzy Wuzzy was a woman!
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #6 on: July 05, 2004, 01:23:51 am »
I got an Arkanoid spinner recently in a box of parts.  It looks good, but it buzzes like mad.  I don't remember it doing that when I played it at the pizza place unless you spun it really hard (like when you were heading for that warp/exit thing on the side).
Is my memory messed up, or is something out of whack with this spinner?  Were the gears lubricated or anything?
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #7 on: July 05, 2004, 01:46:30 am »
I have one too. It does pretty much the same thing.
You have to remember that when installed in a solid commercial quality cabinet, the control panel dampened much of the noise.
On the other hand, it could certainly use a cleaning + re-lube.
NO MORE!!
Kremmit
  • - AHOTW -
« Reply #8 on: July 05, 2004, 11:19:03 pm »
Mine's already really clean- like mabye it was never even used.  But there's no sign of ANY lube on it... that's what I was wondering about.  Where did you lube yours, on the gears, the shafts, or both?  What did you lube with?
Thanx!
