Author Topic: WG 1972. How do I get the.....(Ken Layton help)  (Read 1564 times)
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 09:28:48 pm
« on: June 22, 2004, 12:50:43 pm »
I wen ahead and got the WG 1972 (7200) CGA Monitor.
I gave up on the 19" Neotec Multi-Sysnc cause they wanted $320.00 for the monitor (which is ok to me) but the shipping is $190.00 which made me decide not to order it. So I went to Betson (drove there) and got me the WG 1972 (7200). Now I just to make sure about the setting for Advmame/Advmenu. TIA
how can i get this specs for Advmame ?
pclock
hclock             (this one I think should be 15.75)
vclock
Free VGA Breakout Cable
Ken Layton
  • Guru
  • Technician
Re:WG 1972. How do I get the.....(Ken Layton help)
« Reply #1 on: June 24, 2004, 12:15:05 am »
I only have a catalog sales flyer on the 7200 series and here's all that's listed:
Video type: RGB analog
Video input impedance: 4.7 k ohms standard; other values optional by request
Video level: 1 volt to 5 volts peak-to-peak; other levls optional by request
Sync type: TTL sync; seperate or composite; negative or positive
Sync input impedance: 20k for positive; 12 k for negative
Horizontal sync frequency: 15.75 khz
Vertical sync frequency: 47 to 63 hz
For any other tech info you should phone the tech support dept at Wells-Gardner 1-800-336-6630
Thenasty
« Reply #2 on: June 24, 2004, 02:56:48 pm »
Thanks Ken. I found out the pclock value when I run the Advcfg program. It is listed on the list of Arcade Monitors.
pclock=5-80
hclock=15.75
vclock=47-63
As this moment, I still don't get a steady pic like I did with my old Wg49xxx series. I am still trying but at this point, I think I am gonna get the ArcadeVga. I don't know why I can't get it going. I have no problem with the older monitor (until I gave it a CAP KIT job). Is there a possiblity that I blew up the Flyback Transformer when i did the CAP KIT ? Anyway, those monitor are long gone and I am in this new WG7200. I am just wondering why I can't get it going while I got it going quickly with my old Monitors before (3 years ago).
Did you know that this monitor has both 15.75 and a 17khz switch ?
It did not mention this in any flyers/advertisement I've seen.
Even in mikearcade manual don't mention it.
http://www.mikesarcade.com/arcade/manuals/monitor/WG-K7200.pdf
« Last Edit: June 25, 2004, 12:08:20 am by Thenasty »
Ken Layton
  • Guru
  • Technician
« Reply #3 on: June 24, 2004, 06:36:16 pm »
17 khz?????? I've never heard of any gameboard needing that frequency. 15.750 khz has been the standard horizontal frequency in television sets since 1940 and in arcade monitors since the begining of video games.
Thenasty
« Reply #4 on: June 24, 2004, 07:00:05 pm »
I think this is what they called the Extended CGA (Atari).
Here is a pic.
Here is some specs of klov
http://www.klov.com/monitor.html#R
« Last Edit: June 24, 2004, 07:16:08 pm by Thenasty »
