Author Topic: 1" Thick Cocktail Top  (Read 1406 times)
jcrouse
    • CPViewer
« on: April 02, 2004, 07:19:39 pm »
Where are you guys finding 1" thick material for the top of your cocktail cabinets. I don't want to have to put two pieces of 1/2" together if I don't have to.
Thanks,
John
crsdawg
  • Last login:September 13, 2019, 06:10:05 am
  • I plan to live forever, or die trying.
Re:1" Thick Cocktail Top
« Reply #1 on: April 02, 2004, 09:22:12 pm »
i've heard others have had to make a special order for it from their suppliers(lowes, home depot?). personally 2 pieces of 1/2" seems like a good alternative. screw them together and once you slot it and install t-molding you will never know the difference.
another option is to just use 3/4" which is still plenty strong, just not an accurate repo.
NY_in_TX
  • Last login:February 25, 2017, 11:19:54 am
  • First play's free...next one will cost ya
« Reply #2 on: April 02, 2004, 09:36:08 pm »
I agree with crsdawg, 2 pieces glued or screwed together would be just fine.
I just assumed my cocktail top was 2 pieces of 1/2 inch layered together, but upon closer inspection it is indeed 1 inch..or a very consistent tight glue job (which you indeed could achieve with clamps and screws).
ny
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #3 on: April 02, 2004, 10:35:38 pm »
Check your local information place (phone book, in the USA) for "Lumberyards" or "Lumber".  The lumberyard can and will get you the piece you desire.  It is their business!  Some may not cut to your dimensions, so remember that when searching around.  Your sweet honey-like tone will go a long way towards getting what you want from someone you've never dealt with.
If you want/need something exotic, go to Rockler and you'll be able to get something that thick.  Be prepared to reach through your nose to access your wallet, as that's how expensive their wood is.
If you want cheap, and are thinking plywood, MDF, or some other sheet-good, you can do it easier than you think.  A little Gorilla glue, a few clamps, and a few cauls (ask me if you go this route, I'll explain what a caul is and why you SHOULD use one) and you're in bidness!  It's not as hard as you might be envisioning, and you won't even require screws in it.
« Last Edit: April 02, 2004, 10:41:31 pm by drewkaree »
Tilzs
  • Last login:February 16, 2011, 10:41:56 am
  • Neat
    • Cocktail Arcade
« Reply #4 on: April 03, 2004, 01:29:19 am »
I used 3/4" and then got some of the heavy duty 1/8" felt pads at Home Depot. I then put felt on both the top and bottom of my glass clips which then has the added bonus of not scratching up the paint on the top or the glass :)
Lilwolf
« Reply #5 on: April 03, 2004, 05:49:28 am »
If you make it non standard size...
don't expect to find glass clips for them.  You will have to have something made for you.  Also T-Molding prices will more then double.
just a note... heard others complain about it years past.
NoOne=NBA=
« Reply #6 on: April 03, 2004, 02:40:08 pm »
I THINK I remember seeing 1" at Home Depot; but I'm not sure if the TRUE size was a little either side of that because I didn't measure it.
It was in the aisle with the melamine, and was laminated together like butcher block.
NOTE: For those who are new to all this, the size listed on most materials is a "nominal" size.
The ACTUAL size varies.
The plywood listed as 3/4" is NOT 3/4", it's usually more like 23/32".
I edited the values above
« Last Edit: April 03, 2004, 11:29:38 pm by NoOne=NBA= »
Tilzs
  • Neat
    • Cocktail Arcade
« Reply #7 on: April 03, 2004, 10:10:18 pm »
I think your numbers are off. 11/32 isn't even 1/2" it's more like 1/3 of an inch.
froggerman
  • Last login:March 01, 2015, 03:23:14 am
  • You want how many buttons?!
« Reply #8 on: April 03, 2004, 10:30:52 pm »
I there is a place that sells marine plywood in your area you might try there. 1" is a very common size of marine plywood.
slicer_d
  • Last login:November 06, 2013, 12:51:11 am
  • Yay n' stuff
« Reply #9 on: April 04, 2004, 06:25:47 pm »
I glued 2 pieces of 1/2" together.  I just bought one big piece and cut it in half bunch of wood glue clamps and some heavy stuff on top to get a good bind.  Worked just fine cut the t molding slot and cant even tell the difference.  1" tmolding is a little more expensive but you dont need that much for just the top part.
