Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: Dumbest Monitor Question Ever!!!  (Read 1599 times)
bconpc
« on: July 15, 2002, 09:12:11 pm »
This has got to be the dumbest monitor question ever. I'm having a load of trouble just taking the shell of my monitor. I have a 19" KDS Visual Sensations Model # VS-190i, I have taken the only 2 screws out and it just won't come apart. I've looked all over for other screws and their are none. The pedestal is in 2 parts. One part comes off and the other is attached to the monitor. All I want to do is take this pedestal part off. I thought about mounting the monitor to the chassis I have already but I can't get the casing off without tearing it up. Anyone with ideas as this has been very frustrating.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re:Dumbest Monitor Question Ever!!!
« Reply #1 on: July 16, 2002, 12:22:26 am »
It is not a stupid question.  I've seen stupid people who should have asked it, but didn't, crack the bottom of their monitor casing.  (I hope the pedestal you are talking about is what I think of as the add-on base).
I don't have the KDS Model # VS-190i.  But I did work with a KDS 17" of some type.  Of all the monitors I've seen, all of them had L-shaped hooks that slid into slots in the bottom of the monitor, and one or two snap "locks" to keep the base from sliding out.  Usually the base slid toward the back of the monitor to come off, and the the snap lock was also at the back side of the base.
upside-down monitor with base already off:
                 |_____________|          <--- base
                ]    L     L              <--- snap and 2 L hooks
            |                      |      <--- monitor (front)
(Very bad ascii, but I hope it helps.)  You have to lift the (yellow) snap quite a bit so you can slid the base backwards so the L hooks disengage so you can lift the base.
Robin
Knowledge is Power
Trimeister
  • Last login:July 23, 2002, 06:45:25 pm
« Reply #2 on: July 23, 2002, 06:54:30 pm »
Thats cool drawing u_rebelscum
and for bconpc u_rebelscum was right its not a dumb question at all. I believe u_rebelscum was right KDSes do have clips at the bottom but it may be just a little tight to unclip them but they're there.
Good luck,
Trimeister
