Author Topic: Vertical Games Roll  (Read 5813 times)
Dudeman
  • Last login:August 25, 2026, 12:37:22 pm
  • Ecky ecky ecky ecky P'Tang! Zoop-boing mmmzoesm...
Vertical Games Roll
« on: August 02, 2026, 03:02:56 pm »
I had this working on my cab, then I lost the HDD with everything EXCEPT the OS. Then I found that the backup drive was also FUBAR. So a reinstall it was. Same version of GroovyMame (0.265) because that's the version of the ROMS I have. I'm using an HD6450 connected to a Trinitron 27" TV.
Native vertical game selects 400x288_51 which causes a roll.
With artwork enabled it selects 720x464i@60 and works.
If I specify the resolution in a command line (e.g. mame digdug -resolution 640x480) it presents correctly.
There is no "Creating mode" message for the 288p mode, despite modeline_generation=1.
Any ideas?
Zebidee
  • Trade Count: (+9)
  • Last login:Today at 09:03:43 am
Re: Vertical Games Roll
« Reply #1 on: August 02, 2026, 04:34:36 pm »
Do your 288p modes work in ArcadeOSD?
My guts tell me that your TV (or your installed modelines) have a problem with ~50hz?
Create a log file. If you don't know how, instructions are in Calamity's post sig.
Dudeman
« Reply #2 on: August 02, 2026, 05:34:56 pm »
If I force Mame with -resolution 640x480 it looks fine.
Zebidee
  • Trade Count: (+9)
« Reply #3 on: August 02, 2026, 08:18:01 pm »
That doesn't matter. 640x480i is typically a 60hz mode. That's Basically NTSC (almost), any TV can do that.
If you're in the US (NTSC-land), your TV might only be capable of displaying modes close to 60hz. Which means it won't be able to display 288p as that requires a lower (slower) vertical refresh rate ~50hz (to give the TV the time to draw the extra horizontal lines).
Every TV is a little different, but: If the above matches you, you're using the default generic_15 or arcade_15 monitor profile in VMMaker, and your TV can't display the 288p modes, this is probably the reason.
Try using the default NTSC profile instead.
Ask yourself: Did the TV do 288p modes previously?
« Last Edit: August 02, 2026, 08:20:05 pm by Zebidee »
