Author Topic: 2007 Golden Tee help  (Read 71116 times)
Patrick L
  • Last login:April 17, 2026, 11:39:15 pm
« on: April 08, 2026, 01:43:07 pm »
I was gifted a full arcade version 2007 golden tea. It’s been working great, and then I went away for a week and decided to turn it off to give it a break. Bad move. On start up now I get an error message:  no signal detected; check signal cable.
I checked cables, basic stuff, tried a different power source. Same error. It’s not getting any fan running off of the computer itself. I decided to try some quick troubleshooting, including replacing the power supply. No change. Not sure what I should do at this point, but figured I would reach out to see if you had any advice or parts you think would fix.
I am far from a repair person, but I’m pretty handy and feel pretty confident. I could replace a part if I know what it is.  I’m in northern Florida so not sure what resources are in the area if any.
