Author Topic: Re: GroovyArcade live-CD 2022 (collaborative effort)  (Read 5082 times)
3dfan1
  • Last login:January 15, 2026, 09:48:01 am
« on: December 15, 2025, 09:04:33 am »
hi all, i would like to know if there is a way to update manually mame version inside GA?
i am using GA 2024 version which comes with mame 0.267 but i would like to update to the latest 0.283 if possible or 0.282 at least.
i triyed to update from the GA menu "system update" from which i read update to 0.282 would be performed, so i proceeded with the update, but  when the update ended and i restarted the pc,  GA no longer boots again with an "no such file or directory error" command line error
another question i have is if it is posible from a mame command or desktop linux setting to leave audio in "mono" format by default for al mame games? since the arcade machine have only one speaker,
btw i am not experienced with linux overall
thanks
Substring
  • Last login:Yesterday at 02:50:54 am
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
« Reply #1 on: December 18, 2025, 09:30:21 am »
Hi,
solving this problem is a little complicated, can you join the groovyarcade discord ?
