Author Topic: USB Button LED Control  (Read 1853 times)
rr22520
  • Last login:November 08, 2025, 12:43:40 pm
  • Software dev is my thing
« on: November 07, 2025, 11:18:47 pm »
Hi,
 This is all related to the USBButton use only.
 In PacDriveDemo Visual Studio solution, can anyone explain what
 Set Temporary and Set Permanent do?
Also, I want to set the LED after I poll the switch state, I would like to use fade and flashing if possible?
 Pseudocode example,
          top_of_loop:
              Check button state
               if not pressed go to outer_loop
                 if pressed, set LEDs to active COLOR (r,g,b)
                   inner_loop to recheck while button is pressed
                   while in inner_loop if not pressed now
                      Set LEDs to inactive COLOR (r,g,b)
                       and fade slowly to very dim.
                       while button has not been pressed again
                        it would be great to pulse like heartbeat the LED brightness and fade
                    when button is pressed
                           exit inner loop after set LEDs to a inactive COLOR (r,g,b)
             outer_loop:
                  goto top_of_loop
thx in advance,
Rob
Mr. Peabody
  • Last login:November 11, 2025, 07:08:52 pm
Re: USB Button LED Control
« Reply #1 on: November 11, 2025, 06:43:01 pm »
I recommend asking this in Software.
  • Last login:Today at 12:17:33 pm
« Reply #2 on: November 11, 2025, 08:20:37 pm »
Thread moved.   :cheers:
