Author Topic: No picture through composite on Sony PVM-1441QM  (Read 7140 times)
naujoks
  • Last login:October 16, 2025, 08:51:11 am
« on: October 16, 2025, 08:13:33 am »
I'm getting no picture coming through the two composite inputs on my Sony PVM-1441QM.
The other inputs all work fine (RGB, SVIDEO etc.).
I hadn't actually used the composite inputs for quite a while, but I'm pretty sure they used to work.
I tried various input sources (PS2, VHS camcorder), making sure they (and the cables) work (they work on a different PVM I own).
I tried to connect a SCART adapter to the RGB inputs. The adapter also has a socket for composite. Here I'm also not getting a picture, but I'm not sure if this is actually supposed to work.
Has anyone encountered this problem before and knows where the problem might be?
