Author Topic: hantarex polo keeps ticking after replaced components  (Read 5457 times)
tim van boekel
  • Last login:October 16, 2025, 04:56:49 am
« on: October 16, 2025, 02:51:19 am »
Good morgning everyone,
I need some help with a Hantarex Polo 25-inch monitor. I bought a spare monitor for my arcade. The problem when i bought the chassis was horizontal collapse . I replaced R167, which didn't look good and was very out of tollorance.
When I turned the monitor on, the image was larger, I heard a whistling sound, and the monitor stopped.
When I measured the HOT it was shorted.
what did I do? I measured the diodes according to Randy From's diagram they are oke. I replaced C172, C174, and C175, and replaced the HOT transistor.
I did the lamp test B+130 volts.
Then I turned the chassis back on, and it started ticking again.
Then I added another flyback that worked fine, with the same result ticking
At this point, I'm not sure where to look.
Any tips?
regards tim
Mr. Peabody
  • Last login:June 07, 2026, 04:15:16 am
Re: hantarex polo keeps ticking after replaced components
« Reply #1 on: October 29, 2025, 06:43:35 pm »
Sounds like what happened when mine got 240hz, where the flyback blew....but......perhaps you got the polarity of a cap reversed?
