Author Topic: WTB Trackball cable for Opti-Wiz  (Read 6610 times)
joeH
  • Last login:Yesterday at 06:47:53 pm
« on: September 07, 2025, 12:26:57 pm »
Hoping that somebody here has an extra lying around that they don't need anymore.  Sold out on GGG and after speaking with Randy, it looks like it won't be back in stock anytime soon.  Please reach out if you have one available.
Reference:  https://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=76_85&products_id=261
Zeosstud
  • Last login:May 11, 2026, 02:11:39 pm
Re: WTB Trackball cable for Opti-Wiz
« Reply #1 on: November 25, 2025, 02:08:36 pm »
https://www.arcaderenovations.com/suzo-happ-to-ultimarc-utrak-arcade-trackball-adapter.html
That and 6 dupont connectors and you have a pretty simple solution
« Last Edit: November 25, 2025, 03:30:43 pm by Zeosstud »
joeH
« Reply #2 on: November 26, 2025, 12:06:36 pm »
Appreciate the link.  Would I need to remove the 3 or 4 pin connector, and splice a single pin header to work on the OptiWiz?
  • Last login:Today at 02:40:02 pm
« Reply #3 on: November 26, 2025, 01:24:37 pm »
You can pull the pins from the 1x3 and 1x4 pin Dupont headers and put the X1, X1, Y1, and Y2 pins in the 1x4 header.
If you have any 1x1 and/or 1x2 Dupont headers, use those for the ground and two 5v pins.
If you don't have a 1x2 header or enough 1x1 headers, you can re-use the 1x3 header for the 5v lines and leave the unused connector position hanging.
Ultimarc UTrak encoder pinout:
Optiwiz3 pinout:
EDIT: Looking closer at the cable from ArcadeRenovations, other than red wires for the 5v lines it uses non-standard wire colors.  You'll want to move the pins in a specific order so you don't get them crossed up.
1. Pull the 4-pin connector ground pin and put it in a 1x1 header.
2. Move Y2 to the position that 4-pin connector ground was in.
3. Move Y1 to the position that Y2 was in.
4. Move X2 to the position that Y1 was in.
5. Move the 4-pin connector 5v line to the center position of the 1x3 or to a 1x2 header if you're using one.
5a. If you're using a 1x2 header for the 5v lines, move the 3-pin 5v line to the 1x2 header.
6. Move X1 to the position that the 4-pin connector 5v line was in.
« Last Edit: November 26, 2025, 02:20:54 pm by PL1 »
joeH
« Reply #4 on: November 26, 2025, 03:03:08 pm »
Appreciate the help!
