December 08, 2025, 05:07:31 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Well, that was weird. Outage sorted out. Thank you SirWoogie for saving the day!
Main
Raspberry Pi & Dev Board
How to Flash an Arduino Board: Complete Beginner's Guide
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: How to Flash an Arduino Board: Complete Beginner's Guide (Read 5674 times)
OpenELAB
Trade Count:
0
Full Member
Offline
Last login:December 06, 2024, 04:11:24 am
I want to build my own arcade controls!
on:
November 14, 2024, 04:12:59 am »
Arduino boards are widely used for building smart projects, from IoT prototypes to robotics. Flashing, or uploading code, onto the board is a crucial step. This guide walks you through the
flashing process
using the Arduino IDE to ensure a smooth start.
Step 1: Gather Required Tools
Download the
Arduino IDE
from the official website.
Use a
USB cable
to connect your Arduino board to your computer.
Step 2: Configure the Board and Port
Open the Arduino IDE and go to
Tools > Board
to select your board model.
Navigate to
Tools > Port
and choose the corresponding COM port for your device.
Tip: If the port isn’t detected, try installing necessary drivers.
Step 3: Select the Port
In the IDE, go to
Tools > Arduino Runs On: "Core 1"
Step 4: Flash Libraries
In the IDE, go to
Tools >Manage Libraries
Step 5: Identify Required Libraries
Before uploading your code, ensure you have the necessary libraries installed. For example, if your project involves the
M5StickCPlus
, search for and install the
M5StickCPlus library
using the Library Manager in Arduino IDE.
Step 6: Select and Install the Appropriate Library Version
When installing libraries in the Arduino IDE, it’s important to choose the right version.
Step 7: Select Upload or Verify
more code:
https://openelab.io/blogs/learn/how-to-flash-an-arduino-board-complete-beginners-guide
Troubleshooting Flashing Issues
If flashing the Arduino board fails, common causes include:
Incorrect Board Selection:
Ensure
M5StickC Plus
is selected in
Tools > Board.
Incorrect Port Selection:
Double-check the correct
COM port
under
Tools > Port
Re-flash with M5Burner:
Use
M5Burner
to flash any module from
M5StickC Plus
, then start the process again from step 1.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
