Author Topic: phantomX (formerly RL Lightgun Package) DS AIO/MAME Hooker + MORE!!  (Read 42631 times)
PaCiFiKbAllA
  • Last login:February 14, 2026, 07:59:18 pm
  • ...currently in the matrix...
Re: RocketLauncher Lightgun Package (Updated Modules/DemulShooter & MAME Hooker)
« Reply #40 on: September 06, 2023, 05:12:31 pm »
Hey, what’s going on bro. I have the Cleanup.exe set to run after the module closes.  Lemme know if you have any other questions. Thanks!
Finally got around to include this in my light gun build with Launchbox as the front end. For the games utilizing mamehooker and outputs, I use Rocketlauncher as the "emulator" to run those specific games.  Took me while to get it up and running (it's been at least 5 years since I used Rocketlauncher).  Question about the cleanup.exe, does it run automatically upon quitting rocketlauncher, or do I need to call upon it via script?
PaCiFiKbAllA
Updated the PCLauncher.ini to include the following entry from the latest DS:
Code: [Select]
[Operation Wolf Returns]
target=windows
rom=opwolfr
bandicoot
  • Last login:December 18, 2025, 12:30:46 pm
strange thing with module for flycast sometimes it make a rocketlauncher launcher error , game launch in background but make a black screen error
PaCiFiKbAllA
What flycast module you using? The one in this pack? If your game is running in the background and you get a black screen, it sounds like the emulator is losing focus somewhere.  You said it happens randomly.  How often?
« Last Edit: October 21, 2023, 09:47:33 pm by PaCiFiKbAllA »
bandicoot
i use your module , but finally it seem my flycast version make this error , i took an other one and no problem
PaCiFiKbAllA
Good Afternoon,
For those who have the DS AIO/DS AIO (Lite), I updated the logic in my script so that it updates to DemulShooter v12 properly.  Make sure to grab the updated utility from the link in my sig..   :cheers:
PaCiFiKbAllA
A RocketLauncher Lightgun Package update is inbound!
This one includes just a single mamehook.exe, removes all unnecessary calls to run the other utilities as “admin”, removes the Cleanup.exe, revises the contained modules and also offers a revamped DS AIO utility as well.
Stay Tuned  8)
PaCiFiKbAllA
Totally spaced my audience here  ;D
Updated the first page of the thread with updated links and info!
midd
  • Last login:February 02, 2026, 10:21:25 am
Appreciate this! I've been (im)patiently waiting for the update! lol
PaCiFiKbAllA
My bad man, been busy with work and side quests.  Argon just released an update:
bandicoot
thanks , your update is great
just need a confirmation to keep time
in game.ini
options=
if you can show me an example with to option for example : noinput and nocrosshair ,
option=-noinput , -nocrosshair ( is this correct ?)
cause argonlefou add a wonderfull option -profil=
« Last Edit: July 14, 2024, 03:08:57 pm by bandicoot »
PaCiFiKbAllA
in game.ini
option=
if you can show me an ewmple with to option for example , noinput and nocrosshair ,
When passing the options (single or multiple) it should look like this:
Code: [Select]
options=-noinput -nocrosshairs
There is just a single space needed between each argument with the way I have my utility configured.  Let me know how it works out for you. Thanks!
« Last Edit: July 14, 2024, 01:52:20 pm by PaCiFiKbAllA »
bandicoot
thanks  , will try tomorrow and tell you what ;)  :applaud: :applaud: :applaud:
Marcoqwerty
  • Last login:January 04, 2026, 06:20:39 pm
Hello!
Thank you for the pack! im a long term user of RL so im testing it.  :cheers:
Im using windows 7 on arcade PC.
Actually im getting this error from DS AIO
PaCiFiKbAllA
Hello!
Hey! Thanks for checking out my pack  8)
This is the first time someone has reported an issue with it.  I'll have to boot up my Win7 laptop and test from there in the morning.  Will get back to you then.
Marcoqwerty
Hello!
Thank you a lot for your answer!!! btw im super glad that someone create something of super useful of our RL user!
Im waiting your reply, if i have to do some other test let me know.
 :notworthy:
« Last Edit: August 22, 2024, 07:14:10 am by Marcoqwerty »
PaCiFiKbAllA
Hello!
 :notworthy:
What’s going on dude.  I must have forgotten that I updated my laptop to Win10 from Win 7 a while ago.  So I don’t have a way to test.  I do have another exe for you to try.  I’ll DM you later on with a link to it.
PaCiFiKbAllA
The issue below has been resolved.
I replaced WinHttp with MSXML2.XMLHTTP in my logic.
The latter allows for increased compatibility with Win7 machines.
Marcoqwerty
Thank you to make it compatible with this old OS  :notworthy:
Marcoqwerty
Super special thank you to PaCiFiKbAllA !!!!
He help me to fix a problem with my RL installation and not all works fine ready for new lightgun experience!
Just to know if you got some issue to load the special module of this project, remember to add RLauncher as emulator on the PC GAMES system that you want to use with Demulshooter.
 :notworthy:
PaCiFiKbAllA
« Reply #60 on: September 01, 2024, 01:33:43 pm »
DS AIO and the modules in my RL Lightgun Pack have been updated!
-allows DemulShooter 'profile' argument to be passed from the games.ini
Code: [Select]
[The House of the Dead III]
target=windows
rom=hod3pc
options=-v
profile="HOD_III.ini"
[code]17:51:26.723183 : ---------------- Program Start -- DemulShooter v13.0.0.0 ----------------
17:51:26.724154 : Cmdline arg 0 : -target=windows
17:51:26.724154 : Cmdline arg 1 : -rom=hod3pc
17:51:26.724154 : Cmdline arg 2 : -v
17:51:26.724154 : Cmdline arg 3 : -profile=S:\HyperSpin Attraction\RocketLauncher\Module Extensions\DemulShooter\HOD_III.ini
17:51:26.824024 : Opening Configuration file : S:\HyperSpin Attraction\RocketLauncher\Module Extensions\DemulShooter\HOD_III.ini
17:51:26.825021 : Configuration file succesfuly loaded
PaCiFiKbAllA
« Reply #61 on: September 05, 2024, 05:31:04 pm »
One of my many Mame Hooker display files in action  ;D
https://youtu.be/nJNlWazdWcQ?feature=shared
PaCiFiKbAllA
What's good ppl!
I just recently updated my RL Lightgun Pack.  It includes my custom DemulShooter.ahk class, completely re-written to currently support native DS/MH outputs for the modules included in this pack.
Speaking of modules, if your currently using my RL Lightgun Pack, you can safely delete those modules that came with it (PCLauncher/Model2/MAME/Flycast/SuperModel).
The updated modules contained in this update have been re-named (as to not overwrite any existing modules) i.e. PCLauncher (Lightgun Edition), MAME (Lightgun Edition), etc.
The video below is a quick demo...check it out  :)
RL Lightgun Package **Latest Video**
midd
I just downloaded from the link in your OP. Did you not upload the newest version? I'm not seeing the new modules.
edit: Found the link in the description of the youtube video
« Last Edit: October 10, 2024, 07:28:14 pm by midd »
PaCiFiKbAllA
All links have been updated!
« Last Edit: December 05, 2024, 10:01:50 am by PaCiFiKbAllA »
bandicoot
Re: phantomX (formerly RL Lightgun Package) DS AIO/MAME Hooker + MORE!!
« Reply #65 on: January 02, 2025, 10:00:38 am »
thanks again ;)
i've try to use the profile addon in game.ini with no luck
when i try demulshooter in stand alone command no problem , perhaps you can help me
edit : i'll try with -v for look what happening ;)
Edit 2 : just by adding -profiles="c:\xx.ini" in options line it work great , strange cause i need to put exactly the right way with " " but work so .... for me it's great
Thanks for your work
And for people who's got problem to exist PC game with PCLAUNCHER , remember to add in config game in rocketlaunck in Appwait section the .EXE of your game ;) ;) ;)
« Last Edit: January 03, 2025, 12:27:56 pm by bandicoot »
PaCiFiKbAllA
« Reply #66 on: January 05, 2025, 03:40:56 am »
Hey 👋
Thanks for checking it out.  The profile in the games.ini works as expected.  For example:
[Gaia Attack 4]
target=ttx
rom=
option=-v
profile=“GUN4IR.ini”
It should work like so (as shown in the ReadMe.txt) So long as the profile .ini is in the DemulShooter folder.   You shouldn’t need to pass -profile as an argument in the option= part.  I will confirm tomorrow morning though. 👍
PaCiFiKbAllA
« Reply #67 on: January 06, 2025, 07:44:26 pm »
The profile key in the games.ini works as intended @bandicoot
See attached screenshots.
bandicoot
« Reply #68 on: January 07, 2025, 11:23:06 am »
OK , perhaps i make a mistake ^^  i'll try again this weekend ;)
