Author Topic: Anode Cup - Loose or Tight?  (Read 1725 times)
IronChef
  • Last login:March 04, 2004, 12:18:20 am
« on: March 03, 2004, 05:16:12 pm »
Just putting back together a monitor I took apart (for the first time) and am havnig truoble re-attaching the anode cup.
Now I wish I had my digital camera with me, but since I don't...
Just wondering how far the clip goes in and how tight it should be.  It's a pretty rigit clip and with some strength I can get the two little claw parts into the tube, but I am wondering if it is supposed to go in deeper... or is it the function of the suction cup to hold it in?
Thanks.
Ken Layton
  • Guru
  • Technician
Re:Anode Cup - Loose or Tight?
« Reply #1 on: March 03, 2004, 06:07:52 pm »
The clips go under the edge of the hole to make the electrical connection and the suction cup holds things in place.
IronChef
« Reply #2 on: March 04, 2004, 12:20:10 am »
Thanks for the info.
I took another looked at it, and it physically looked impossible for the clip to go in any further... without basically having to squeeze the clip with Superman like power.
JoeB
  • Last login:November 24, 2025, 05:49:35 pm
  • NES Fanatic
« Reply #3 on: March 05, 2004, 12:05:30 pm »
The clips are just that, clips to hold it in place.  The cup just keeps it sealed from other things from going in.
It shouldn't be as tight as a screw, at the same time it shouldn't be super loose..  It does have a small amount of play.
Hope this helps.
