Author Topic: Coin 1, Coin 2, Start 1, Start 2, and 2 player controls on lr-fbneo. SOLVED.  (Read 6137 times)
  • Last login:November 29, 2025, 04:34:53 pm
Hey all,
I've been able to get most of my ROMs working on lr-mame2003 in Retropie, but some I have to force to lr-fbneo. In this case, for example, Rolling Thunder only seems to run under lr-fbneo, which restricts my control set somewhat.
Under lr-mame2003, I have mapped Y, X, LS, B, A, RS, Coin 1, Start 1, Select, and Start for my Player 1 controls. For lr-fbneo, however, it seems to restrict the configuration to a 'Retropad' so that my coin button is mapped to Select, the Start Button is forced to start the game, and my separate Coin and Start buttons can no longer be mapped at all.
Does anyone know any way to 'copy' the lr-mame2003 controls over to the lr-fbneo configuration? (I also tried installing lr-mame2010, and it also seems to force the retropad configuration.)
I'm hoping someone has a solution so that I can have very close to a single configuration for my buttons.
Thanks in advance!
Ninja Edit: I *think* that lr-fbneo and lr-mame2010 have all changed from keyboard emulation (which lr-mame2003 supports) to gamepad emulation only... I wonder if perhaps I need to upgrade my Xin-Mo 2P encoder to an encoder which supports gamepad emulation... I would think it should allow support for an 8-way joystick, 6 game buttons, the coin and player 1 buttons, as well as select and start inputs, wouldn't it? Hmm.
Second edit, with solution: Ah, Retroarch. You confusing, confusing software. So, when I enter the Retroarch menu using the Select + X button, it jumps into the "Quick Menu" which has a section called "Controls". This is where I was previously unable to configure my Coin 1, Start 1, Coin 2 and Start 2 buttons. To fix this, I clicked the B button until I was at the top-level menu, then went into "Settings", and then "Input". From here, I have access to the controls for "Port 1" and "Port 2", which allowed me to set up the configuration for my Coin 1, Start 1, Coin 2 and Start 2 buttons. Then, I returned to "Quick Menu" and set up the buttons for my Coin 1, Start 1, Coin 2 and Start 2 buttons, and then saved the entire Core file. Once I restarted, the controls worked as I had hoped.
Hopefully, someone else can find this useful.
« Last Edit: April 28, 2023, 02:51:21 pm by Rick »
Let's expand on this, shall we? (Since I'm going through this again with a new cabinet, and it's been since about 2023 since the last time I've looked at this.)
Enter your game. Press SELECT and X to enter the RetroArch Menu. Press B to exit the Quick Menu and be brought to the Main Menu. Highlight SETTINGS and press A:
While in SETTINGS, highlight INPUT and press A:
Highlight RETROPAD BINDS and press A:
Highlight PORT 1 CONTROLS and press A:
In my personal configuration, I have the SELECT and START button for these mapped to BUTTON 8 (my 1P COIN BUTTON) and BUTTON 9 (my 1P START BUTTON), so I have changed that here:
Press B until you reach the Main Menu, highlight SETTINGS and press A:
Highlight CONFIGURATION and press A:
Finally, highlight SAVE CONFIGURATION ON QUIT and press A:
Use the B button to exit to the main menu, select QUIT and press A to exit. This should save all of your configuration items to remap the Coin and Start button.
Note: If you edit the port controls from inside the Quick Menu (Main Menu/Quick Menu/Controls/Port # Controls) they WILL NOT work when you exit and try them. It took me a number of times fiddling and configuring to determine this. So, hopefully, this saves you some annoyance!
Good luck with your configuration!
MartyKong
  • Last login:November 24, 2025, 01:22:36 pm
Quick question - It's been a while since I set up Retoarch using Retrobat software. I remember being able to set up both keyboard and gamepad controls for player 1 but player 2,3 & 4 would only allow gamepad controls. Do you think setting it up your way would allow keyboard control for 2,3 & 4? Thanks, Marty
