Author Topic: Galaga (Namco rev. B) - MAME machine best version of MAME to play most accurate  (Read 2757 times)
john12abey
  • Last login:October 18, 2024, 07:59:59 pm
Hello All,
Been long time since posting here again! Glad to be back
So I have four different versions of mame 0.73  .116  .180  .224 and all play a little different   oldest one in the cab plays the best firing and moving correctly old computer
newest version I5 computer with Xbox wireless one controller on new tv play like garbage I dont know if its the front end launchbox just found it looking at emulators again.
Question  to play most accurate version of the game what version and front end should I be using ( i did take the pole and .8 people use launch so I will switch or just compile my own?
Thanks John
Pin Cab is the reason I have Came back 10 year old cab still runs great need update soon
el3venth
  • Last login:December 14, 2022, 08:37:42 am
As per wiki quote:
"The stated aim of the project is to document hardware, and so MAME takes a somewhat purist view of emulation, prohibiting programming hacks that might make a game easier to run at the expense of emulation accuracy." - https://en.wikipedia.org/wiki/MAME
So I would think that the latest MAME is always the most accurate.
Frontend does not matter since it just loads MAME.
negative1
  • Last login:November 26, 2025, 08:35:30 pm
As per wiki quote:
that is true, the latest version is the most accurate.
they made some fixes recently to fix the background stars, which were not correct in earlier versions.
later
-1
john12abey
Thanks for the relies will run latest version!
Thanks John
