Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: Megatouch Key part number  (Read 1249 times)
Spank
  • Last login:September 19, 2023, 07:48:47 pm
  • I like to help out.
« on: May 05, 2022, 11:19:06 am »
Is there anyway to find out the key part number without having the correct software? I have a few keys that faded and the part number cant be read. Also have a few keys missing labels.
I know some were from less popular games like Funzone, kidspace, and gametime. I just cant read the part numbers and it would take a long time trying to install all the different versions of software to try to figure them out.
« Last Edit: May 05, 2022, 01:04:42 pm by lilshawn »
Dazzzzz
  • Last login:July 29, 2023, 07:21:38 am
Can you read any part of the key information? feel free DM if you dont want to post key info on the forum
« Last Edit: May 05, 2022, 11:30:22 pm by Dazzzzz »
lilshawn
  • Moderator
  • Last login:Today at 12:06:10 am
Re: Megatouch Key part number
« Reply #2 on: May 05, 2022, 01:05:14 pm »
i split this into it's own topic, since it warrants it's own discussion.
Spank
« Reply #3 on: May 05, 2022, 04:33:05 pm »
I don't know enough to do it, Is there something that would read it off one of the force square io boards in either Windows or Linux?
mahkeymike
  • Last login:September 21, 2023, 12:26:15 pm
« Reply #4 on: May 05, 2022, 05:09:48 pm »
look at the last two digit family code on the etched serial# if its 02 or 82 then you can rule out 2007 - 2014 And also, those keys are password protected so trying to read the data on them wont do you any good unless you figure out the password.
« Last Edit: May 05, 2022, 05:12:45 pm by mahkeymike »
Dazzzzz
« Reply #5 on: May 05, 2022, 06:14:17 pm »
I dont know anyway of dumping earlier keys using a simple solution or without using the Megatouch itself to dump them (but you would need to know the version to do it so no good)
Not sure of any other methods
« Last Edit: May 05, 2022, 11:27:07 pm by Dazzzzz »
Megatouchmike
  • Last login:September 22, 2023, 06:04:44 am
« Reply #6 on: May 05, 2022, 10:02:30 pm »
Easier way. Emailed you with details
