Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: JVL Encore questions  (Read 4252 times)
rooter
  • Last login:October 14, 2021, 01:31:15 pm
    • ShaunRoot.net
« on: October 04, 2021, 10:33:08 am »
I recently purchased a JVL Encore that would not boot up. I put in a new SD card with HD3 in it and now it boots up and plays fine. There is no security key in the machine, but it's for home use, so free play is fine.
Every other time I boot the machine, I get the message, "ERROR: alsa modules for ALSA". I think maybe this has to do with the clock constantly being reset to January 1, 2007. Every time I set the date in the config, it resets itself back to January 1, 2007. I thought it might be the battery, which I replaced, but if that is the problem, machines will usually save the date until you reboot. In this case, the clock resets itself immediately when I hit the save button. Does not having the security key keep you from saving the date?
Is there a better way to shut the machine down other than just flipping the switch?
The joystick is super wonky. I calibrated it, but it still barely registers. Is this a common thing? Does it likely need a replacement or just a cleaning or something else?
I don't have ethernet hooked up at the moment. Is there anything I can do with that, like backup the hard drive, add artwork for the advertisements, or any other cool things?
The machine appears to support WIFI, but it doesn't have the hardware installed. Can I cram a small USB wifi device in there or does it need something specific?
Is there any official or unofficial way to play tournaments these days?
Is there a legitimate way to buy a  security key?
lilshawn
  • Moderator
  • Last login:Yesterday at 11:26:24 pm
Re: JVL Encore questions
« Reply #1 on: October 14, 2021, 12:36:03 pm »
this is unusual, but take note, there is a couple batteries in this unit. (computer/IO board) be sure to change them all then reset the bios. see if that fixes it.
no. actually it's designed to NOT be turned off at all. it's meant to run all the time out in the wild. while turning it of doesn't usually damage anything, it sometime can, resulting in having to reload the software.
the joysticks where all trash, this is why they where eliminated later on in all bartop units. someone spills the tiniest little bit of something on them and they stop working properly. about the only thing you can do is try and disassemble the pad, and clean out the pots with contact cleaner or isopropyl alcohol.
not a thing. ads are handled through the operator panel if you press the button and look through the menus.
no such system exists any longer. the company that made the system (JVL) has moved onto other things and abandoned the hardware, consequently all server services have ceased.
no. see above.
they are not likely available new. you would need to start contacting distributors and see if they might have something still kicking around. i haven't the foggiest where you are located at, but we have previously ordered from Betson, Playdium, starburst (now player one), BMI, etc. But chances are pretty low.
see the issue is, this was the last of this unit, and as such...most of them where sold off. to get a premium for a machine that is basically worthless, you'd put in the last/latest version you could to squeek out that last couple hundo out of it. so not much parts and whatnot remains.
your best bet might be to run across a key being sold off used as parts from a damaged or otherwise unrepairable machine. in which case, eBay is going to be your best chance to get an hd3 key.
rooter
    • ShaunRoot.net
« Reply #2 on: October 14, 2021, 01:31:15 pm »
Wow, thanks for all the amazing info!
I replaced both batteries in the machine and it still didn't work, but I figured it out. There is a bug in the JVL software that will not save dates past 2018. However, you can go into the BIOS and set the date there and everything will be fine.
