Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: JVL Retro - The Missing Plug (Help)  (Read 4677 times)
pudealee
  • Last login:August 08, 2021, 01:04:35 am
« on: August 02, 2021, 10:38:20 pm »
I undertook the task of removing the CPU in order to possibly upgrade the software. I was very careful in labeling all of the wires and their connection points - with the exception of one. It's the plug at the bottom of the CPU box. When I pulled the plug, I was quick to label it. Unfortunately, when I was able to reveal where it went - there were three possibilities. Eeeek! See below. Any idea which one of these three identical plugs gets the wire?
« Last Edit: August 04, 2021, 03:22:58 am by pudealee »
mahkeymike
  • Last login:Yesterday at 07:52:42 pm
Re: JVL Retro - The Missing Plug (Help)
« Reply #1 on: August 04, 2021, 12:33:25 pm »
If i am not mistaken, I believe they are all tied to the same circuit. Not sure why there is extra connectors. Double check with a multimeter just to be sure though.
pudealee
« Reply #2 on: August 04, 2021, 09:14:22 pm »
Thanks for the reply. I'm not exactly sure how I would use my multimeter to check this. I have only basic knowledge on using my MM (fuse continuity, voltage, etc ).  ::)
Megatouchmike
  • Last login:Yesterday at 10:18:36 pm
« Reply #3 on: August 08, 2021, 08:33:25 pm »
continuity is exactly what you should be checking for, like I told you on ebay
lilshawn
  • Moderator
  • Last login:Yesterday at 05:04:53 pm
« Reply #4 on: August 11, 2021, 03:37:25 pm »
yes, i can confirm, all 3 ports are identical.
