Author Topic: Cruis'n World leg levelers - where to get?  (Read 4760 times)
AE35
  • Last login:January 18, 2022, 01:48:24 pm
  • That sure is a nice raygun!
« on: July 24, 2021, 01:15:32 pm »
Hi guys
I am working on restoring my Cruis'n World sitdown arcade. The leg levelers are pretty crusty on the main cabinet, so I want to change them for new ones. I originally thought that these would be the same as are present on pinball machines, but they are a lot bigger - at least on the seat section...see picture below. Any advice where I can get them (maybe in Europe)? Black would be cool :)
  • Last login:Today at 06:32:12 am
Re: Cruis'n World leg levelers - where to get?
« Reply #1 on: July 24, 2021, 11:57:08 pm »
Looking on page 43 of the manual here, it shows the leg leveller P/N 08-8023 has 1/2"x13 threads.
Based on this listing, it appears that P/N 08-8023 is 4-1/4" long.
https://www.betsonparts.com/amusement-redemption/leg-leveler-1-2-13x4-1-4.html
With those two specs, it shouldn't be too hard to find a suitable replacement.   :cheers:
AE35
« Reply #2 on: July 25, 2021, 03:52:46 am »
Hi
Thanks for the information!
I can get the length in cm, but how on earth do I get cm from 1/2"x13? I have no idea what the x13 means  :)
« Reply #3 on: July 25, 2021, 05:42:57 am »
I doubt you'll find a suitable metric substitute for just the original leg leveler.
- If you can't find an SAE/imperial-measurement leveler, you're better off replacing both the leveler and the plate it threads into.
When describing threads, you need to know the diameter and the pitch -- the distance between threads.
1/2" = 12.7mm (diameter)
The x13 indicates 13 threads per inch ==> 1"/13 threads = 25.4mm/13 threads =  1.9538mm/thread (pitch)
- Imperial pitch can also be indicated with a dash.  i.e. a #4-40 machine screw indicates 40 threads per inch.
AE35
« Reply #4 on: July 31, 2021, 02:55:31 pm »
Thanks for the advice...I will look into what to do then :) I wish they were just standard pinball-leg-size levelers :)
