Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: Road Burners HDD replacement error  (Read 3685 times)
at1105
  • Last login:November 06, 2021, 12:37:04 am
« on: July 08, 2021, 08:32:07 pm »
The hard drive in my Road Burners was starting to fail so I decided to replace it. The original was a 160GB Maxtor IDE and I replaced it with a WD 500GB SATA (using an IDE to SATA adapter). I wrote the CHD image to the new HDD using CHDMAN. When I power it on it gives the error...
found no valid home blocks
QIO error, EOF on file
I verified the CHD file and it passed. Maybe it's due to the larger HDD? Or maybe because it's SATA and I'm using the IDE to SATA adapter?
Andre
  • Last login:December 23, 2021, 08:21:46 am
Re: Road Burners HDD replacement error
« Reply #1 on: December 23, 2021, 08:19:48 am »
Have you tried using Reflect Macrium to clone the disk?
It can be with GPT and not MBR that you use in the old ones.
classicjoe72
  • Last login:August 05, 2022, 09:39:55 am
  • I want to build a Fix-It-Felix Jr.!
« Reply #2 on: April 27, 2022, 09:12:43 am »
Any luck with this?  I just wanted to add that CloneZilla has always worked for me doing exactly this.
