Author Topic: will these work for connecting wire?  (Read 778 times)
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« on: February 24, 2004, 11:01:31 pm »
okay, i have 22ga wire that im going to use to extend the power wires coming from my mobo so i can hook it up to a pushbutton to power on  the cab.  anyway, will these things work for connecting the stripped wires together??
tmasman
  • Last login:January 04, 2024, 03:50:44 pm
  • Hello...
    • My (no so up to date) Home
Re:will these work for connecting wire?
« Reply #1 on: February 24, 2004, 11:06:26 pm »
Yup...
They work great to splice together 2 wires end-to-end.
I used something similar to quick disconnects for the wires coming out of my PC so I could easily detach the wires that ran to the button in the cab.  I also left the wires attached to the PC's power button so I could easily remove the PC to work on it...
But if you're looking for a permanent solution, those will work great.
I'm not a freak!...
Oh wait...
Yes I am...
