Author Topic: De-soldering Iron  (Read 3378 times)
J_K_M_A_N
De-soldering Iron
« on: May 19, 2020, 09:23:58 pm »
Can anyone recommend a somewhat cheap de-soldering iron? I don't want to go with a $250+ one as I will not use it very much (at this point). I would like to keep it under $100 if possible. Do those little 40W irons with the bulb work ok?
J_K_M_A_N
J_K_M_A_N
Re: De-soldering Iron
« Reply #1 on: May 19, 2020, 09:47:06 pm »
Is it worth going with this or just get one of these?
J_K_M_A_N
« Reply #2 on: May 20, 2020, 08:27:13 am »
Personally, I like the cheapy ones. I'm not exactly pulling anything more delicate than capacitors, though. one of those and a glass jar to spit it back out.
I like it better than those suction syringes as well, because I feel like I have better control with bulb irons.
J_K_M_A_N
« Reply #3 on: May 20, 2020, 10:29:13 am »
I ordered up the cheaper one. I will probably not use it a whole lot so I will try that one first. I am having trouble getting a row of pins out with the hand held solder sucker. It leaves just a little bit connected and I can't seem to get it even with the copper braid. :(
J_K_M_A_N
  • Last login:Yesterday at 12:31:00 pm
« Reply #4 on: May 20, 2020, 11:52:50 am »
The bulb one should be fine for minimal work, but if you think you’re going to be doing a lot of work eventually, consider going with a desoldering gun. I bought one a few years ago and have never looked back!
bperkins01
« Reply #5 on: May 20, 2020, 12:00:48 pm »
A little more that $100
https://www.amazon.com/Desoldering-Station-Digital-Temperature-Controlled/dp/B00KQ6PR6K/ref=sr_1_1?dchild=1&keywords=zd-985&qid=1589990366&sr=8-1
This is a good alternative..  having a vacuum desolder is the best..
I have it and I've had very good luck.
Ken Layton
  • Guru
  • Technician
« Reply #6 on: May 20, 2020, 12:57:22 pm »
Since I do a lot of board repairs, I use a Hakko model 808 desoldering gun. Sure makes things much easier and faster. However, the 808 is discontinued (was superceeded by the FR-300 model and that one is now replaced by FR301). As usual, Hakko products are expensive.
« Reply #7 on: May 20, 2020, 01:35:01 pm »
I use an 808 as well. Probably the best investment I ever made for this hobby.
  • Last login:Yesterday at 07:58:26 pm
« Reply #8 on: May 20, 2020, 01:43:51 pm »
I rigged up a cheap suction bulb iron to some tubing and a shop vac on a foot switch.  Worked great for pulling 40 pin chips off an old pinball driver board.  Cost me about $30 in materials.
Bad part was the shop vac pulled solder further up the metal shaft than I think is normal and at one point I had to put it in the BBQ to get it red hot and pour out the solder.
On the other hand, $30.
J_K_M_A_N
« Reply #9 on: May 20, 2020, 02:48:59 pm »
If I can make this cheap one work, it will probably be fine for how much I will use it. If it sucks, I don't mind spending $100-$150 to get the vacuum style and just having it for future use. It is really nice to have the right tool for the job. I have been going crazy trying to get this off. I would rather spend the money and make life easier.
J_K_M_A_N
« Reply #10 on: May 21, 2020, 09:01:36 am »
PBJ solutions may cause unexpected problems, but don't worry, because there are PBJ solutions for that.
J_K_M_A_N
« Reply #11 on: May 24, 2020, 10:45:10 am »
I got the cheaper one and it works decently enough. I was able to get it apart and since I will probably not do this a whole lot, it should be good for me. I had to kind of loosen the pins after de soldering but they finally broke free. Thanks for the advice all.
J_K_M_A_N
