Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: Good tube/chassis monitor for MAME?  (Read 553 times)
Iflippedthecanoe
  • Last login:March 23, 2020, 10:47:23 am
« on: March 21, 2020, 10:04:01 am »
Im looking for a good all around horizontal arcade monitor for a multicade MAME build. I really don't know the differences between monitors at all. Im looking for a good resolution to play 8bit to games up to 3D arcade games and decent scanlines and quality obviously would be nice!!! :notworthy:
arfink
  • Last login:February 27, 2021, 11:42:17 am
  • Narf!
Re: Good tube/chassis monitor for MAME?
« Reply #1 on: March 21, 2020, 10:25:26 am »
So, first things first: what games are you going to play? Actual examples would be good, because you make it sound like you plan to play console games and that can make a really big difference if you want to play 5th gen or newer. You also need to understand that there's different resolutions of arcade games. Most will be low-res CGA, a few will be medium res, and a few will be higher res. If you just want to pick a good all-around tube, pick a CGA tube. If you have loads of cash, pick a tri-sync that can do all 3.
Iflippedthecanoe
« Reply #2 on: March 21, 2020, 11:47:49 am »
Oh damn ok that helps to know. I don't really plan on spending more than $400 but the games I want to play are 1st through 6 gen console games. Also want to play lots of arcade games from 2D to 3D. So basically everything. But If I had to choose I just want a clear monitor that works good with 16bit-ish games and good scanlines if possible.
Iflippedthecanoe
« Reply #3 on: March 21, 2020, 11:50:15 am »
A monitor that makes Mortal Kombat 3 look good would be good I think...
arfink
  • Narf!
« Reply #4 on: March 21, 2020, 12:58:12 pm »
MK3 is a CGA/standard res tube. 16 bit games and most of your 80s and 90s arcade titles will also play well on a standard res tube with very few exceptions. N64 and Playstation will probably look like ass on a CGA tube, but you probably don't want to play the majority of those on an arcade stick in the first place, so I wouldn't worry about it.
Iflippedthecanoe
« Reply #5 on: March 21, 2020, 04:54:58 pm »
Ok that helps. I do plan on playing 3D mame games but CGA might work for me, maybe idealy a tri sync would be the best all in one monitor?
Also are there higher end higher resolution CGA monitors out there? Also what would be a good make/model for CGA/tri sync or anytything else?
Iflippedthecanoe
« Reply #6 on: March 21, 2020, 04:59:11 pm »
I also have a monitor called an Effinet EFG-1701M/F , but i have no idea what the quality of that model is...
arfink
  • Narf!
« Reply #7 on: March 21, 2020, 09:23:40 pm »
If money is no object, Nanao brand is considered exceptional, they came in Japanese candy cabs and are some of the finest. They're available in CGA and tri-sync. As for the EFFinet thing, if it's reasonably new, probably not a big deal to use it. Contact the manufacturer for a data sheet if you need it.
https://effinet.en.ec21.com/CRT_Monitor--762751_762764.html
