Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: Teraburst gun to Guncon 2 project. I need a little help on the relay connection.  (Read 1029 times)
Zebra
  • Last login:January 23, 2021, 04:41:39 pm
I have been converting my Konami Teraburst guns to use as Guncon 2 machine guns on my PS2 and PC:
It's a relatively straight forward project as there is enough room in these shells (after a little dremel work) to fit an (almost) un-modified Guncon 2 board:
It only required that I cut the trigger wires from the ribbon cable to connect them to the new guns trigger button. And cutting the start / select board to wire it to the button on the front grip. The button on the bottom of the GC2 grip is going to a pedal I have.
The part I am struggling with a little is using my DC / DC solid state relay to activate the recoil motor with the guns trigger switch:
I can activate a regular powered relay board I have with the trigger (as it has it's own 5v psu) but the GC2 trigger doesn't seem to have enough power to activate the solid state relay.
The SS relay activates with as little as 3v (apparently). Any thoughts on why the GC2 trigger does not activate it would be appreciated....
Has anyone here had any luck using a solid state relay with a GC2 trigger? Did it require an additional mosfet?
gstav
  • Last login:Yesterday at 10:52:09 pm
    • forum.arcadecontrols.com/index.php/topic,157861.0.html
Did you ever got this project to fly? Would be awesome to see the guns in action  :cheers:
"One coin to rule em' all"
