Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: Trackball sensitivity adjustment on JAMMA board cabinet  (Read 942 times)
atxcpa38
  • Last login:June 28, 2020, 07:08:55 pm
« on: February 06, 2019, 12:11:44 am »
Hi there, Iím new to the forums and to custom/home arcades, so I hope someone can answer what is probably a pretty basic question, but one for which I canít find an answer.
I recently bought a newly built tabletop cabinet with the iCade 60-in-1 jamma board, which included a Happ 2 1/4 trackball.  So, is there a way to adjust the trackball sensitivity on this, and if so is it done through the DIPSW 4 settings, or is it an adjustment to the trackball hardware?  The trackball works pretty well, but I prefer a bit more responsiveness than what it has now.  Thanks in advance.
atxcpa38
Re: Trackball sensitivity adjustment on JAMMA board cabinet
« Reply #1 on: February 07, 2019, 12:35:04 am »
Could some please answer another question I have about the trackball on my new machine?  I think part of the problem is that I definitely notice now that there are serious response issues when trying to move in the down direction on the trackball.  It just doesnít always respond when I try to move the shooter down the screen when playing Centipede or Millipede.  Physically, the ball rolls fine, itís just the response that is a problem in that one direction.
This is not an Arcade1up machine, but Iíve seen many people claim that lubricating the parts (not the ball itself, I guess itís the rollers or bearings, I donít remember) with a silicon grease fixes the issue.  However, I recently watched a video with a man explaining how to clean a trackball, and he specifically mentions not to oil any of the parts when cleaning it.
So, what is the proper way to possibly fix my trackball?  Should I just lubricate the correct parts as some suggest, or just clean it without any lube/oil?  This is a brand new machine, so Iím kind of suprised that Iím already having issues with the trackball.  But if it just needs a little cleaning, then that doesnít sound too hard.  Thanks for any advice as Iím new to all of this!
« Last Edit: February 07, 2019, 02:15:35 am by atxcpa38 »
  • Last login:Today at 07:17:28 pm
  • card carrying purist
« Reply #2 on: February 07, 2019, 05:24:44 am »
60 in 1 is a ---smurfy--- board. If your trackball is a new Happ then it is probably not the problem. A guy I know might still have his 60 in 1. I will ask him if there are any trackball adjustments. I doubt it though.
atxcpa38
« Reply #3 on: February 07, 2019, 09:02:21 pm »
I think I figured out what the problem is.  The control panel is tilted at a 17-degree angle.  I didnít think about this until I took the trackball out and it worked just fine when level.  When I put it back it, it again has problems moving up and down.  Anyone else think this might be the issue?  If so, I will be returning it.  From what Iíve seen 17 degrees sounds a bit more angled than usual, but it wouldnít have bugged me otherwise.  Curious what others think.
paigeoliver
  • Last login:December 17, 2020, 11:17:40 pm
  • Awesome face!
« Reply #4 on: February 08, 2019, 10:18:09 pm »
The problem is the 60 in 1. The trackball settings are off on the board and there is no way to change them. Buy bootleg chinese garbage and it performs like bootleg chinese garbage.
