Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: Testing RTSS Scanline Sync on groovymame 0.205  (Read 653 times)
NaNo1982
  • Last login:March 06, 2019, 09:26:23 am
« on: January 19, 2019, 10:03:28 am »
Hello, my name is Nano, then I will show you how to use the new feature of the RTSS software, the idea is to use this alternative method of V-Sync which practically does not generate imput lag, my setup is as follows:
A-10 7850k
8gb RAM DDR3
1tb disk
windows 10 (without activation) xD
Groovymame 0.205
TV sony trinitron 29 "
converter scart to component video
Razer atrox controller
I leave this video that uploaded to youtube, in the first run you can see the terring image that generates without V-Sync in the upper part of the trees, in the second run it disappears completely without generating any type of imput lag.
« Last Edit: January 19, 2019, 10:09:51 am by NaNo1982 »
Calamity
  • Moderator
  • Last login:October 12, 2019, 11:09:54 am
  • Quote me with care
Re: Testing RTSS Scanline Sync on groovymame 0.205
« Reply #1 on: January 23, 2019, 03:28:25 am »
Hi NaNo1982,
This vsync method is very interesting indeed, as a proof of concept: handling vsync externally to the rendering engine.
With regards to GM, it won't add any benefit latency-wise, and I'll probably be a little worse since it doesn't allow positioning input polling with respect to the raster, like frame delay does.
Steps to create a log:
 - Attach resulting romname.txt file to your post, instead or pasting it.
NaNo1982
« Reply #2 on: January 23, 2019, 07:31:17 am »
Undoubtedly the best is the option of frame_delay, but it is a quite demanding option especially for PC with integrated graphics cards. It is not a definitive option, but it was worth trying, thanks for clarifying, regards!  :afro:
