Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: 2 player spinner help  (Read 1394 times)
pixelpalace
  • Last login:February 08, 2019, 10:31:12 am
« on: January 18, 2019, 12:39:21 pm »
I am trying to get Forgotten worlds to work but running into an issue. I am using push/pull spinners. Player 1 works beautifully but when I add player 2, the spinner for player 2 controls player 1 as well. The push/pull works independently for each player but i cant figure out why player 2 is controlling player 1.  They are are on separate boards and separate USB inputs.
processedmeat
  • Last login:December 13, 2020, 12:46:51 pm
  • Ikeakade Here I come!
Re: 2 player spinner help
« Reply #1 on: January 18, 2019, 12:56:49 pm »
Try setting multimouse to "1" in the mame.ini file.
pixelpalace
« Reply #2 on: January 18, 2019, 12:59:21 pm »
I should add that I am using advancemame and configuring everything in the advmame.rc file. Should I still change it in the .ini file?
processedmeat
« Reply #3 on: January 18, 2019, 01:05:19 pm »
Sorry, just realized I responded to the raspi post.  On normal mame you would do that.  Not sure about Advancemame.
processedmeat
« Reply #4 on: January 18, 2019, 01:07:59 pm »
Did you look at this link yet for Advancemame?
https://github.com/RetroPie/RetroPie-Setup/wiki/Spinners,-Trackballs,-Lightguns,-and-other-Mouse-Devices
Scroll down a bit until you get to the advancemame section for mouse/spinners
pixelpalace
« Reply #5 on: January 18, 2019, 01:29:55 pm »
Yup. And while it was very helpful in initially getting the spinners running, its not much help now.  :)
processedmeat
« Reply #6 on: January 18, 2019, 01:39:00 pm »
When you cat /dev/input/mice do you get two separate axes?  Have you tried another emulator?
processedmeat
« Reply #7 on: January 18, 2019, 01:42:43 pm »
I assume this is the same issue as your TurboTwist post.  I know that this product uses the X axis exclusively so maybe if you have both masters they are using the same axis?  Yeah, I would try to get a hold of RandyT to see if he has more insight on this.
pixelpalace
« Reply #8 on: January 18, 2019, 03:29:42 pm »
I actually got the main issue resolved. The push-pull works great. And i actually had them both working perfectly. I shut down the machine, came back and this new problem popped up.
Knowing they use X exclusively, gives me an idea. In the config, it currently is setup this way.
input_map[p1_dialx] mouse[0,x] mouse[1,x] mouse[2,x] mouse[3,x]
Input_map[p2_dialx] mouse[0,y] mouse[1,y] mouse[2,y] mouse[3,y]
I am going to try changing p2_dialx to p2_dialy
