Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: Replacments parts CD4011AE CD4012AE -> CD4011UBE  possible?  (Read 818 times)
perjmolsen
  • Last login:June 29, 2020, 06:51:09 am
  • I want to learn, and try.. I NEWER give up :)
    • My gameroom
« on: January 17, 2019, 05:38:40 am »
Hi  :cheers:
Hope some one smarter than me can help me a bit :)
I have this old Double or even machine.
The top print where the lights is does not work, but the game works fine - its just the lights.
I have checked and repaired the PSU, so now all the correct volts are present, but the lights still not work.
All the bulbs are fine - just one is lighting up.
So i guess that the missing lights i caused by the controller board.
I have replaced all the caps on the board but no difference (the old one where blown)
So my attention is on the IC's on the board now
There is a lot but mostly
CD4011AE -> https://www.datasheets360.com/pdf/4567507543728082358
CD4012AE -> https://www.datasheets360.com/pdf/4567507543728082358
I am unable to find the IC's online - so i have got some
CD4011UBE -> http://www.ti.com/general/docs/suppproductinfo.tsp?distId=26&gotoUrl=http%3A%2F%2Fwww.ti.com%2Flit%2Fgpn%2Fcd4011ub
If I compare the two IC's data sheet they look the same.. can i replace the old ones with the new?  ???
Again I need som expert advice  :applaud:
My plan is to put in some sockets at the PCB when i remove the old IC's so it is easier to change the IC's in the future.  :)
« Last Edit: January 17, 2019, 05:41:13 am by perjmolsen »
perjmolsen
    • My gameroom
Re: Replacments parts CD4011AE CD4012AE -> CD4011UBE  possible?
« Reply #1 on: January 17, 2019, 05:40:16 am »
The machine
perjmolsen
    • My gameroom
« Reply #2 on: January 17, 2019, 06:03:06 am »
A bit more information and pictures of the OLD stuff :)
The only lights that light up is the one "even" in right side.
The lights in the middle all lights up, that is background lights so i guess only the lights in the side has to do something when i pull the handle
perjmolsen
    • My gameroom
« Reply #3 on: January 17, 2019, 07:10:59 am »
A update more :)
I have checked that there is going power to the CD4011AE CD4012AE at pin 1 (+) and pin 14 (-)
All the chips has around 13V in.
Its also random what bulb that light up when i turn the machine on..
Now it is the top one who is lighting up...?!?
perjmolsen
    • My gameroom
« Reply #4 on: January 17, 2019, 07:15:48 am »
The best diagram i can find to a similar machine is this one... but i am a bit lost :)
